Hello everyone, I have a small issue with my Ikea Brimnes furniture. Specifically, there are minor scratches and some small chips on the surfaces caused by everyday use. Since I really like these pieces and would prefer not to buy new ones, I am looking for practical and simple methods to reliably repair such minor damage. I am interested in tips for surface touch-ups as well as techniques to keep the appearance as close to the original as possible. Does anyone have direct experience with repair kits or special methods for Brimnes furniture? Which tools or materials work best? I look forward to your helpful advice and perhaps some background information on the material of this furniture. Thanks in advance!
I would like to add that when dealing with chipping, it is important to match the original texture as closely as possible. Otherwise, the repair will be very noticeable.
It is also advisable to spread the filler evenly to avoid visible transitions. Sometimes applying several thin layers and allowing each to dry thoroughly can help.
PULAU schrieb:
A professional method I can recommend is using repair wax combined with a hot air tool.That sounds interesting! I know repair wax from hardwood flooring, but have you had success using it on furniture with melamine coating? Also, would I need to buy a special hot air tool for this, or is a regular hairdryer enough? I only have a basic hairdryer at home.
Gelen schrieb:
I know repair wax from hardwood flooring, but have you had success using it on furniture with melamine coating?Yes, it works well for minor scratches. The challenge is that the wax cannot restore the melamine surface itself; it only masks the damage visually. For chips, it is not sufficient.
Gelen schrieb:
Would I need to buy a special hot air tool for this, or is a regular hairdryer enough?Usually, a standard hairdryer is enough for heating. It’s important that the wax gets hot enough to melt, but the surface should not become too hot to avoid damage.
I really like that so many helpful answers are coming in here! Repairing Ikea furniture is truly enjoyable when you have the right tools. If you take your time and follow the steps carefully, the repairs are barely noticeable afterwards! Just keep at it and don’t be afraid of small mistakes!
I would like to give one more tip regarding color selection: When you are looking for furniture touch-up sticks at the hardware store, it’s best to take a small piece of your furniture with you or take a photo in good lighting to match the color as accurately as possible. Otherwise, the sticks tend to be either too dark or too light.
When using the stick, apply it with light pressure to build up thin layers of color. More is not necessarily better in this case.
