Some time ago, I bought an Ikea Hemnes bookshelf made of solid pine wood. Unfortunately, there are already a few scratches on it that spoil the overall appearance. Since the wood is untreated and rather light in color, these scratches are quite noticeable. I’m interested in learning which products and methods are best for repairing or at least visually improving small to medium scratches on Hemnes pine furniture.
It would be great if you could share your experiences – especially I’m curious about:
- whether there are specific repair kits that have proven effective
- how to deal with deeper scratches
- if natural home remedies work
- and how to best treat the furniture after repair to preserve the result
Thanks in advance!
Thanks in advance!
Nathanaelk13 Feb 2024 12:37Hello ilirpin,
You have formulated a very precise and helpful question, which makes answering much easier. I assume your Hemnes furniture piece is either oiled or waxed, as Ikea usually delivers these surfaces that way, which is important for the repair.
If you have scratches of different depths, you should proceed as follows:
- First, it is useful to clean the surface because dust and grease hinder the repair. Use a mild, pH-neutral cleaner and a soft cloth.
- For small superficial scratches, I recommend special wood repair wax sticks or putty that matches the color of pine. Carefully fill the scratches with this and then smooth it out with a plastic card or your finger to remove excess material.
- For deeper scratches, fine-grit sandpaper (around 240-320 grit) is worthwhile. Lightly sand the scratch to smooth the edges without removing too much wood.
- After that, you can use a suitable wood stain or wood marker to restore the color of the wood.
- Finally, I recommend treating the area with a suitable oil (e.g., linseed oil or a special wood furniture oil for pine) to protect the surface and adjust the tone.
With natural home remedies, success usually stops quickly—for example, walnut oil or beeswax can provide superficial cosmetic improvements but are only limitedly effective for deeper scratches.
Could you please let us know if your furniture is oiled, waxed, or lacquered? That would help refine the recommendations.
Nathanaelk schrieb:
Could you also mention whether your furniture is oiled, waxed, or lacquered? That would help to refine the recommendations.Thank you for the detailed response! My Hemnes shelf is actually oiled, which is also stated on the product page, and it feels quite matte and natural. This probably makes it somewhat more sensitive to scratches. Your advice about using wax sticks and oil makes a lot of sense to me. In this context, is there a difference between oil specifically made for furniture and, for example, linseed oil from a hardware store? Should I preferably use a specialized product?
I’m also interested in the best way to care for the repaired area after oiling to avoid further damage as much as possible. Is regular re-oiling recommended, or is it sufficient to simply dust the furniture carefully instead?
In summary:
- Special furniture oils are better suited for oiled pine wood furniture than linseed oil from hardware stores, as they often contain additional ingredients that nourish and protect the wood.
- Linseed oil can be used as an alternative but tends to dry more slowly and may become sticky if applied incorrectly.
- Furniture oil designed specifically for oiled wood surfaces provides better protection and is easier to apply evenly and smoothly.
For maintenance, I recommend:
- Regular dusting with a soft cloth to remove dirt and dust.
- Depending on use, applying a thin layer of furniture oil every 6 to 12 months. This helps prevent drying out and new scratches.
Important: Before applying more oil, the surface should be clean and dry. For areas with heavy use, treatments can be repeated more often. This improves the durability of your piece of furniture.
PeoDaniel14 Feb 2024 09:11Hello ilirpin,
I would like to add that for oiled furniture made of light pine wood, like Hemnes, applying pure linseed oil is not ideal, as it often does not seal properly. Special furniture oils also contain UV protection, which helps prevent the wood from yellowing.
If you use the wax stick, be sure to pay attention to the color—too dark can look unnatural. It’s best to test it in an inconspicuous spot first.
Regarding preparation:
- Make sure the repair area is completely dust-free.
- For very deep scratches, a fine sanding pad can help lightly roughen the surface so the oil penetrates better.
I recommend wiping the area briefly with a damp cloth after sanding and then drying it before applying the repair material.
Regular maintenance is advisable, especially for furniture in heavily used areas.
