ᐅ How do I repair scratches and dents on Ikea Hemnes furniture?
Created on: 23 Apr 2018 10:17
Nonkurt
Hello everyone, some time ago I bought a chest of drawers from the Ikea Hemnes series and use it daily. Unfortunately, over time some scratches and dents have appeared on the surface, especially on the visible table and cupboard areas. I am now looking for a reliable and as simple as possible guide on how to repair these damages without having to sand down or repaint the entire surface. What materials or tools are best to use, and are there any special techniques recommended for Hemnes furniture, since these often have painted or waxed wood surfaces? I want to avoid the repaired spots standing out or looking different from the rest. Thanks for your advice!
LANICOLE
24 Apr 2018 12:15
Nonkurt schrieb:
Can you say exactly which paint pen you used?
I mostly use so-called acrylic wood paint pens with a matte finish. These work quite well because they don’t dry too glossy and usually match the silky finish of Hemnes furniture nicely.
Nonkurt schrieb:
The scratch on my dresser is about 3-4 cm (1-1.5 inches) long and 0.5 cm (0.2 inches) deep – it feels pretty hollowed out.
For such deep scratches, I recommend a two-step approach:
- Use wood filler or putty that can replace wood pieces or fibers. Important: apply the filler in several thin layers to ensure it stays firm and doesn’t crack.
- After it’s fully dry, smooth the surface with fine sandpaper (grit 240-320).
- Then use a paint pen or a small brush with acrylic varnish to visually blend the surface.
Make sure to dust off thoroughly and keep the area clean during repair, or the paint won’t adhere well. For bigger dents, furniture wax is not an option as it doesn’t fill well.
If you want to be absolutely sure, you can also apply a suitable primer beforehand to even out any color differences.
Merlin52
24 Apr 2018 13:41
A brief addition on the topic of touch-up pens and color matching:
- It is always worth testing small areas in less visible spots to ensure that the appearance and gloss level are accurate.
- Some users have also had good results with wood oil or wax on untreated or very lightly lacquered areas, but for Hemnes furniture, which is usually finished with acrylic lacquer, I consider touch-up pens to be the better choice.
- For deeper scratches: Sometimes it is advisable to seal the area again with a fine spray of clear lacquer after filling and sanding.
This makes the repair more durable and the result more uniform.
Avery
25 Apr 2018 08:19
If you can't find pens, you can also apply regular acrylic paint in the desired color with a small brush. Important: Apply very thinly in layers, otherwise it will remain visibly thick.
LANICOLE
25 Apr 2018 11:54
Avery schrieb:
If you can’t find pins, you can also apply standard acrylic paint in the desired color using a small brush.
It is important to stir the paint well before applying and to test its compatibility with the furniture material. Also, choose the brush carefully—a fine synthetic brush is ideal for creating smooth surfaces without brush marks. Afterwards, don’t forget to do a light sanding with very fine sandpaper and use a polishing cloth to achieve an even shine!
