ᐅ How do I repair scratches and dents on Ikea Hemnes furniture?
Created on: 23 Apr 2018 10:17
NonkurtHello everyone, some time ago I bought a chest of drawers from the Ikea Hemnes series and use it daily. Unfortunately, over time some scratches and dents have appeared on the surface, especially on the visible table and cupboard areas. I am now looking for a reliable and as simple as possible guide on how to repair these damages without having to sand down or repaint the entire surface. What materials or tools are best to use, and are there any special techniques recommended for Hemnes furniture, since these often have painted or waxed wood surfaces? I want to avoid the repaired spots standing out or looking different from the rest. Thanks for your advice!
Hello Nonkurt,
First of all: Good idea to approach the repair as locally as possible; this saves time and materials. IKEA Hemnes furniture is usually made of solid lacquered pine wood or veneered surfaces with a lacquered protective layer. You can usually fix small scratches and dents with these steps:
- Cleaning: First, clean the damaged area thoroughly, for example with a damp cloth and mild dish soap, to remove dirt.
- Light sanding: For deeper scratches, you can use very fine sandpaper (grit 400-600) to smooth the edges of the damage.
- Filling material: For small dents, there are color-matched wood fillers or repair wax sticks that I recommend.
- Application: Apply the repair paste lightly with a small spatula or cotton swab and smooth it out afterward.
- Finishing: After drying, gently smooth with very fine sandpaper and, if necessary, dab on paint or varnish from a hardware store.
Typical for Hemnes are the white or natural-colored lacquers – here you can often get matching touch-up pens at IKEA or specialty stores. Small mistakes during application can be tolerated at first; with some patience, it looks very good in the end. Important: Test colors and fillers beforehand in an inconspicuous spot.
Summary: Clean, sand, fill, varnish, and lightly touch up. If you want more detailed information about the type of varnish or specific products, feel free to ask!
LANICOLE schrieb:
A typical feature of Hemnes furniture is the white or natural-colored paints – you can often find matching touch-up pens at IKEA or specialty stores.This is an important point. Hemnes furniture is indeed coated with a multi-layer paint that is quite durable. For minor surface repairs, solvent-based touch-up pens or repair kits that dry quickly and provide good adhesion are suitable.
It is crucial to carefully prepare the substrate for deeper scratches, as otherwise the paint may peel off. If the surface is not thoroughly cleaned before repair, there is also a risk that the paint will detach later.
Additionally, you should match the paint tones as precisely as possible and avoid applying shades that are too dark on light wood, as this will be noticeable.
In conclusion: rule number one is clean preparation, followed by properly dosed and thorough application of the touch-up paint. A quick and solid finish can also be achieved by applying furniture wax or clear varnish afterward for protection and shine.
Hello Nonkurt,
I’d like to add a step-by-step guide based on what I’ve done with Hemnes:
- Step 1: Clean the damaged area, preferably with isopropyl alcohol to degrease.
- Step 2: If there are cable ties, gently roughen the area around the scratch using fine sanding pads (not paper).
- Step 3: Choose a suitable wood wax stick. Important: pearl effect or satin finish variants are also available.
- Step 4: Apply wax from multiple angles and in several layers since the wood grain often varies.
- Step 5: Immediately remove any excess with a soft cloth.
- Step 6: After curing (usually 24 hours), lightly buff with a polishing cloth to minimize shine differences.
Common mistakes:
- Applying wax too thickly, which makes it look sticky.
- Letting color tones differ too much (better to match as closely as possible).
This method is usually more effective for minor surface damage than paint because it is more flexible and better simulates the gloss.
One more tip: For larger damage, a repair kit with wood filler and paint/varnish might be more suitable. Best regards!
Common mistakes:
Hey everyone! I love how helpful tips are shared here! Recently, I had a really bad scratch on my white Hemnes dresser. Here’s how I fixed it:
- First, I carefully checked whether the wood underneath was still intact or if it was just the paint layer that was damaged.
- Then I used white wood filler (bought specifically at the hardware store) to completely fill the dent.
- Let it dry thoroughly—it really takes a few hours!
- After that, I carefully repainted the area with a white furniture touch-up pen (with a brush).
- In between, I smoothed it out with very fine sandpaper (grit 800).
Now you can hardly see it anymore! 🙂 It’s amazing what you can achieve with a bit of patience. I’d say it’s definitely worth repairing a Hemnes piece since the furniture is so nice otherwise. It’s worth sticking with it!
Pome60 schrieb:
I would say that repairing Hemnes furniture is definitely worth it, because the pieces are otherwise so nice.Thanks, that really motivates me right now! Could you tell me exactly which touch-up pen you used? There are so many, with different sheens, and I’m a bit unsure.
Also, I’m wondering how to best deal with especially large dents. The dent on my dresser is about 3-4 cm (1–1.5 inches) long and 0.5 cm (0.2 inches) deep – it feels quite hollowed out. Is wood filler plus touch-up paint enough, or does it require more work?
It would be great if someone could go into more detail about these bigger repairs.
