ᐅ How can I repair finish damage on Malm furniture?
Created on: 13 Nov 2024 08:37
U
Umutsi
U
Umutsi
13 Nov 2024 08:37
Hello everyone, I have several IKEA Malm furniture pieces in my apartment that unfortunately show small but visible surface damage from daily use—such as scratches or chips in the finish. My question is quite specific: How can I repair Malm furniture to restore its original appearance as easily and durably as possible when it comes to finish damage? I am especially interested in which repair methods work well for the thin melamine or lacquer layer on the surfaces, how to best prepare the affected areas, and whether there are special products recommended for Malm furniture. I want to avoid the repair being noticeable or deteriorating over time. Has anyone dealt with finish damage on Malm furniture and can share detailed advice for a proper yet not overly complicated repair?
Jensson
13 Nov 2024 12:04
Hello Umutsi, I think your question is very well formulated because you specifically address the material properties and the repair needs. Here is a brief guide on how I would proceed with paint damage on Malm:
1. Preparation: Gently sand the damaged area first with fine sandpaper (grit 400 or finer), only until rough edges disappear. Be careful not to sand too deep, as Malm furniture is usually covered with a thin layer of paint or melamine.
2. Cleaning: Then remove sanding dust and grease – ideally with a slightly damp cloth and some dish soap, followed by thorough drying.
3. Repair material: For small scratches or chips, special paint pens or repair kits for furniture are recommended. These can be found at hardware stores and match the common Malm colors quite closely. The most common color is white or white painted.
4. Application: Apply the paint thinly and in several layers, allowing each layer to dry before applying the next. Finally, you can gently smooth the surface with very fine sandpaper (grit 800–1000).
5. Sealing: If the original paint was very glossy, I recommend applying a clear water-based sealer at the end.
Typical mistakes include applying paint too thickly or sanding through the painted layer down to the wood.
I hope this helps you for now!
Filippo
14 Nov 2024 07:28
Jensson schrieb:
For small scratches or chips, special touch-up pens or furniture repair kits are recommended
You hit the nail on the head with that, Jensson, but I would like to clarify a bit further and go deeper into the material structure of Malm to avoid potential mistakes.
Malm furniture is usually made of particleboard with a melamine resin coating or a very thin paint layer. This means the surface is hard and scratch-resistant, but also thin. If the paint is already chipped or deeply scratched, the underlying material is often particleboard or a white underlayer.
Regarding your question, Umutsi: preparation is crucial. If you only roughly sand the damaged area with coarse sandpaper, you risk destroying the surrounding protective layer, which can lead to unsightly, larger repair spots.
Here is my detailed step-by-step suggestion:
1. First, lightly sand only the edges of the chip with very fine sandpaper (grit 600 to 800).
2. If the damage is more significant, definitely use a furniture repair filler (e.g., white acrylic filler) to level out the surface somewhat.
3. After the filler has fully dried, gently sand the area smooth with fine sandpaper.
4. Use high-quality touch-up pens or small cans of acrylic or acrylic paint in the exact color code of Malm (usually RAL 9003 Signal White or RAL 9016 Traffic White). I always recommend doing a color sample comparison, as there can be slight color variations depending on the production year.
5. Apply the paint in several thin layers, sanding lightly with ultra-fine sandpaper (grit 1000) between coats to achieve a smooth result.
6. Finally, I recommend sealing the repair with a two-component clear coat with a matte or satin finish, depending on the finish of your furniture piece.
I have often noticed that users apply too thick layers or skip proper preparation, which makes the repair visible or not durable. Precise preparation with fine sanding and filler evens out irregularities and ensures perfect paint adhesion.
Could you perhaps briefly describe how large the damaged areas are on your Malm and whether they are only superficial? That would help tailor the advice more precisely.
warrenka57
15 Nov 2024 19:46
Umutsi schrieb:
I want to avoid the repair being noticeable or deteriorating over time as much as possible.
I completely understand how frustrating these paint damages can be – especially when a piece of furniture is still relatively new and you don’t want to replace everything right away. I had the exact same problem a few years ago with my Malm dressers.
What I learned is that patience is a crucial part of the process. Rushing the repair rarely leads to a good result, and the flaws tend to be quite visible.
Even though DUVIN and ju_ren don’t write long posts here, I want to share one tip based on my experience: never use harsh solvents to clean the surface before repairing! The thin melamine coating can dissolve or become dull.
For me, after sanding, it worked well to carefully wipe the area with what I’d call a “damp cloth” (using a small amount of water and mild soap) and let it dry completely.
I also did small paint touch-ups with fine brushes and always waited several hours between layers, even though manufacturers often recommend only 30 minutes.
Don’t worry, with some care and attention, the imperfections will soon be barely noticeable. I hope this gives you some confidence 🙂 How far along are you with your repair, or have you already tried something?
