ᐅ How do I repair Malm drawer hooks?
Created on: 16 May 2021 09:37
V
vural
V
vural
16 May 2021 09:37
I have a problem with my IKEA Malm dressers where the metal hooks that connect the drawers to the drawer slides have broken. These are the typical hooks on the sides that grip into the slide to prevent the drawer from falling out. I believe the material is plastic, but I’m not entirely sure. My specific question is: How can I properly repair or replace these Malm drawer hooks?
Which replacement part is recommended, and what is the best way to remove and reinstall them without damaging the drawer or the cabinet? Is there perhaps a repair method using glue, or is there a better alternative to simply replacing the hooks?
I would appreciate a detailed guide or practical tips to quickly restore the functionality of my Malm drawers.
nera59
16 May 2021 10:48
Hello vural,
First of all, thank you for the detailed description of your problem – it makes things much easier.
Regarding the Malm drawer hooks: these are usually made of plastic, and when they break, it is often more practical to replace them rather than repair with glue, as the stress from opening and closing the drawer is quite high.
1. Spare parts procurement: IKEA itself offers replacement parts for Malm dressers, although these are not always readily available. One option is to ask for the damaged hooks at an IKEA store using the dresser’s article number (e.g., 302.284.41). Alternatively, searching in forums or on eBay for original or compatible replacement hooks can be worthwhile.
2. Disassembly: To remove the drawer, pull it out completely. On the left and right sides, you will find the hooks that engage with the runners. Using a small screwdriver, carefully pry the hooks out of their slots. Take care not to damage the thin plastic housing of the drawer.
3. Assembly: Gently slide the new hooks into the corresponding slots on the drawer until you hear a slight click. Then you can reinsert the drawer and test it.
4. Repair with adhesive: If replacement parts are not available, a very strong, flexible plastic adhesive (e.g., a special 2-component glue) can be used. The broken surfaces must be cleaned thoroughly first. However, keep in mind that such repairs are often only temporary.
Summary:
- Prefer replacement parts
- Careful disassembly and assembly
- Adhesive repair only as a last resort
I hope this helps! If you have specific questions about steps 2 or 3, just let me know.
GALEO4
17 May 2021 14:53
nera59 schrieb:
Prefer Spare Parts
This is, of course, the classic advice, but I wonder if IKEA, with its resources, shouldn’t eventually move toward simpler solutions. The Malm drawers are basically disposable when a small plastic hook breaks — why not use some metal or at least reinforced plastic?
nera59 schrieb:
Repair Glue Only as a Last Resort
Why exactly? With modern epoxy resins or plastic adhesives, you can create durable bonds if applied properly. I think the DIY community underestimates these possibilities. Of course, you have to pay close attention to the forces involved, but alternatives to spare parts should receive more focus, also to conserve resources.
What do you think? For me, sourcing spare parts is often the bigger problem, and a cheap adhesive is quickly at hand.
Kabau
18 May 2021 08:06
GALEO4 schrieb:
Spare parts procurement is often the bigger issue for me
If spare parts are hard to find, just make hooks from sturdy wire; they work well. Most Malm drawer hooks are simply holders. There’s no need to wait for an original part.
For repairs: remove the hook, bend a new one, insert it, done.
Practical, inexpensive, and ready to use immediately.
