ᐅ How do I repair scratches on IKEA Hemnes furniture?
Created on: 20 Jul 2023 08:37
Eneskar
Eneskar
20 Jul 2023 08:37
I’ve noticed some unpleasant scratches on my IKEA Hemnes furniture, especially on the painted surface of the dresser. My question is: What is the best way to repair scratches on IKEA Hemnes furniture myself so that the result is as inconspicuous and durable as possible? Are there specific materials or techniques suitable for the often matte and painted finish? I’d prefer not to sand down or repaint the entire surface, but rather look for practical solutions for small to medium damage. Any kind of advice on treating the wood, paint, or sealant on Hemnes dressers or similar furniture would be very helpful. Thanks in advance!
U
uslis47
20 Jul 2023 09:46
Hello Eneskar,
Your question is very well formulated and clear. Hemnes furniture, which is usually made of solid pine wood with a lacquer finish, offers several ways to repair scratches depending on their severity:
- For minor scratches, a specialized wood touch-up pen in the matching color often works well. These pens are usually available at hardware stores or furniture retailers and can be applied easily to visually blend the scratch.
- For deeper scratches or abrasions, you can carefully use fine sandpaper (grit 320 to 400) to lightly smooth the surface. Afterwards, applying a suitable clear lacquer or furniture polish will help restore the protection.
- Colored wax sticks are also a simple alternative for small dents, as they can be gently worked into the scratches.
It is important to test any color products on an inconspicuous spot first to avoid color mismatches.
If you like, I can gladly offer tips on which products are especially suitable for the lacquered Hemnes surface.
Franck
20 Jul 2023 10:12
I recommend the following for Hemnes furniture, depending on the scratch depth:
- Small scratches: furniture touch-up markers in the matching color
- Medium scratches: wax sticks or furniture wax
- Larger damage: clear lacquer for polishing
No expensive measures are usually needed.
Surela
20 Jul 2023 14:05
Hello Eneskar,
To fully answer your question, let’s first take a closer look at the material properties of Hemnes furniture:
Hemnes is traditionally made from solid pine wood, sealed with a thin layer of lacquer or clear varnish to make the surface more durable and achieve the typical matte finish. This makes repairing scratches somewhat challenging, as the wood underneath is visible and the protective lacquer is compromised.
Step-by-step repair process:
- Step 1: Clean the surface with a mild household cleaner to remove dust and grease. This is essential to ensure good adhesion of any subsequent treatment.
- Step 2: For very fine scratches, a wax repair stick in a matching color is the first option; rub it into the scratches with a cloth or your finger. For more visible scratches, a wood touch-up marker is suitable, which you should choose as close as possible to the color of your furniture. These markers are usually available in various wood tones as well as for white or black furniture surfaces.
- Step 3: If the damage is deeper, you can gently sand the affected area with fine sandpaper (grit 320 or finer) to smooth the edges. Important: only sand as much as necessary to avoid damaging the surrounding lacquer layer.
- Step 4: After sanding, apply a thin coat of clear varnish with a fine brush or sponge to the spot. This is necessary to restore the protective layer and visually blend the repair with the surrounding color.
Special furniture polishes that can even out micro-scratches are also recommended. Some products are formulated with PTFE or carnauba wax, which makes the surface smoother and reduces the visibility of small scratches.
One more question: What color are your Hemnes furniture pieces (white, natural, dark) and approximately how large are the scratches? This way, I can better recommend the most suitable products.
Eneskar
21 Jul 2023 07:58
Surela schrieb:
One more question: What color are your Hemnes furniture pieces (white, natural, dark), and how large are the scratches approximately? That way I can better suggest the right products.
Thank you for the detailed response! My Hemnes dresser is painted white, and the scratches vary in size—some are small, just a few millimeters (under half an inch), while others are longer marks around 5 cm (2 inches) that penetrate a bit deeper into the wood. I hope this helps you make a better recommendation.
BiDennis
21 Jul 2023 12:22
Basically, white Hemnes lacquer finishes are somewhat more challenging to repair because the color tone and gloss level must match. Here are my tips for white furniture:
- For small surface scratches, repair creams or pastes designed for white wood often suffice. These can be applied thinly, allowed to work, and then polished.
- Longer and deeper scratches should first be gently smoothed with fine sandpaper. Then use a white wood touch-up pen or color mixing pen specifically made for lacquered furniture.
- Afterwards, a clear coat is recommended in a matte version to preserve the original surface gloss.
- Alternatively, you can buy small bottles of liquid white lacquer and retouch the affected spots.
My advice here is also to test the products first in an inconspicuous area, as color accuracy and the matte finish may vary.
Eneskar schrieb:
My Hemnes dresser is painted white and the scratches are partly small (a few millimeters), partly longer scrapes about 5cm (2 inches) that go somewhat deeper into the wood.
This shows that a combination of wax stick or lacquer pen plus sanding and repainting is truly the best solution.
