ᐅ How do I repair Ikea HEMNES furniture damaged during transport?
Created on: 13 Oct 2023 08:37
FOGANA
FOGANA
13 Oct 2023 08:37
Hello everyone, I recently received several Ikea Hemnes furniture pieces that obviously suffered damage during transport. There are significant dents on the surfaces as well as small cracks on the edges. Since I want to fix this myself and cannot immediately contact Ikea customer service, I am looking for specific tips or proven methods on how to best repair Hemnes furniture with these kinds of transport damages. What is especially important for me:
- Which tools and materials are particularly suitable for the paint and wood surfaces of Hemnes?
- Are there practical techniques to make dents less noticeable visually?
- How can I repair any cracks or small chips in a stable and long-lasting way?
If anyone has had similar experiences, I would greatly appreciate detailed advice. Thanks in advance!
Davidleo
13 Oct 2023 09:05
Hey FOGANA! Great that you want to tackle the repair yourself! 💪 For HEMNES, combination methods work really well:
- For small dents and scratches, wood filler or wood putty in the right color can work wonders.
- Use wood or touch-up markers (often available at IKEA or hardware stores) to blend color differences.
- Small cracks can be filled nicely with wood glue or special wood repair compound, then sanded and carefully painted.
Very important: patience! Intermediate sanding helps a lot to achieve a smooth finish. And don’t panic right away—minor mistakes can often be fixed later! Good luck!
bapar
13 Oct 2023 10:47
Hello FOGANA, to answer your question precisely, it would be helpful to know the exact extent and location of the transport damage. In general, I recommend the following approach:
- Clean the surface: Before any repair, the areas must be free of grease, dry, and clean.
- Small scratches and dents: Wood filler, matched to the color tone, can be applied very well with a small putty knife. After drying, file and sand until the surface is completely smooth.
- Cracks/edges: Gluing with wood glue is the best option here. If larger pieces have broken off, they must be fixed first, if necessary with small clamps or bar clamps.
- Painting: For HEMNES, the surface is usually painted. A thin layer of matching acrylic or paint can be applied with a soft brush or sponge. Make sure not to apply too thick a layer to avoid paint runs or surface unevenness.
I recommend choosing repair materials in a shade as close as possible to the original color since HEMNES has a sometimes very subtle stained surface that looks better when dulled after touch-up work.
If you like, you can provide more detailed information and photos, and I can help you more specifically.
te-min
13 Oct 2023 11:23
I recommend: wood filler for dents, wood glue for cracks. Then sand and touch up with suitable paint markers. Done.
Curtis
14 Oct 2023 07:52
Davidleo schrieb:
Very important: patience! Sanding in between coats makes a huge difference to achieve a smooth finish.
This is a key point that many people underestimate. Often, work is done too hastily, resulting in a repair that looks more like a fix rather than a proper solution.
However, I wonder how sensible it is to try to repair certain transport damages yourself instead of relying on the warranty or guarantee. IKEA usually offers good customer service, especially with new products. In some cases, attempting a self-repair might even jeopardize goodwill from IKEA.
What do you think? When do you believe a DIY attempt is really the best option, and when is it better to file a claim immediately?
andre3
14 Oct 2023 09:16
Curtis schrieb:
Ikea usually has good customer service, especially for new products.
That’s true. In cases of legitimate transport damage, you should always contact customer service first.
DIY repairs are more appropriate
- when the warranty or claim period has expired
- or when quick fixes are needed and the damage is relatively minor.
The repair methods mentioned here (wood filler, sanding, touch-up pen) are generally proven techniques for wood surfaces.
Important: Document the damage before repairing. This way, you stay protected in case a claim is necessary.
