ᐅ How can I fix drawer runners on Ikea BESTA units that are sticking or rubbing?
Created on: 8 Aug 2020 10:23
ManfeHello everyone,
I have an issue with my Ikea Besta cabinets where the drawer slides sometimes rub or stick when I pull the drawers out or push them back in. This causes the drawers to no longer operate smoothly, and I’m worried that over time this could damage the guide rails.
My question is: What is the best way to repair or adjust these drawer slides so they work smoothly and effortlessly again? Are there any special tools or replacement parts recommended for this? And is it usually worth repairing them, or is it more practical to replace the entire drawer slide system?
It would also be helpful to know what most often causes the rubbing or sticking, so I can target the underlying problem more effectively.
I look forward to any tips and shared experiences, thank you in advance!
Most often, the squeaking is caused by accumulated dirt or deformations in the metal guide.
First, thoroughly clean the rails and wipe them dry.
Then, remove the drawer completely and check if the plastic runners are intact.
Replacement parts from Ikea or third-party manufacturers often fit. It is usually worth replacing them.
SauDietmar8 Aug 2020 15:47Hello Manfe,
First of all, it is important to precisely identify the source of the problem. Jamming or sticking in Ikea BESTA drawers can have several causes:
- Dirt or dust on the drawer slides
- Bent or warped metal runners
- Worn plastic glides
- Incorrect assembly or loose screws
My suggestion for a systematic repair is as follows:
1. Remove the drawer completely: Ikea BESTA drawers can usually be fully pulled out easily.
2. Visual inspection and cleaning: Clean the drawer slides with a soft cloth and, if needed, some dish soap. This removes any buildup.
3. Check the plastic glides: These are often the wear points. They can be ordered as replacement parts from Ikea customer service or specialty retailers.
4. Inspect the slides for deformation: If bent, they can sometimes be carefully straightened with pliers, but be cautious not to cause further damage.
5. Tighten screws: Loose screws can cause misalignment and friction.
6. Optional: Apply lubricant, such as silicone spray or a dry lubricant that does not attract dirt.
If the drawer slides are severely damaged, a full replacement is advisable. Replacement slides from Ikea are relatively affordable and easy to install.
Summary: Cleaning, checking the plastic glides, tightening screws, and lubrication are the most important immediate steps. Obtain replacement parts if necessary and do not reuse bent components.
I hope this helps you.
SauDietmar schrieb:
First of all, it is important to precisely locate the source of the problem.This is a sensible approach. Additionally, I would like to point out the following:
- Ikea BESTA drawers typically use metal runners with plastic slides, which can cause noise and rubbing when worn.
- Regularly checking the screw fastenings is especially important, as these often loosen under stress and lead to misalignment.
- A dry silicone-based lubricant is ideal because it supports smooth movement without attracting dust. Oil or grease can worsen the problem over time.
In my experience, replacing the plastic slides usually makes more sense when there are issues with the drawer running smoothly, rather than replacing the entire runner, as this is often cheaper and faster to do.
However, if the runners are bent, definitely get replacements. Ikea sells these parts separately, and there are compatible third-party products available, some of which are more durable.
My advice: Work step by step to identify the exact cause of the rubbing. This helps avoid unnecessary effort.
