ᐅ How can I fix dented edges on Billy shelves?
Created on: 9 Jul 2015 18:37
moli5
moli5
9 Jul 2015 18:37
I own several Billy shelves from Ikea, which I am quite fond of. Unfortunately, some edges have become dented—meaning there are indentations caused by bumps or accidentally leaning against hard objects.
Now I’m wondering: What is the best way to repair these dented edges on Billy shelves?
It’s important to me that the repair is as inconspicuous as possible, since the surface is coated and not solid wood. Maybe there are household remedies or DIY tricks to remove or at least disguise the dents?
I would also like to know if anyone can advise on how to prevent material damage to the edges, so this kind of thing doesn’t happen in the future.
Looking forward to tips and experiences! How do you handle small dents or pressure marks on your Billy shelves?
reybo
9 Jul 2015 19:04
moli5 schrieb:
How can I best repair these dented edges on Billy shelves?
Hello moli5! That’s a very good and precise question! Billy shelves are made of particleboard with a wood veneer or melamine coating, which makes the repair a bit more challenging.
For dented edges, the common practice is first to check whether the coating is damaged or not. If the melamine film is intact, trying to roll out or steam the dent can be difficult. Often, moisture combined with heat causes slight swelling of the material beneath the coating, which can be used to your advantage.
Here is a step-by-step guide I recommend:
1. Gently moisten the area with a damp cloth—but avoid soaking it.
2. Place a clean cloth (preferably cotton) over the dent.
3. Set an iron to medium temperature (without steam) and apply it on the cloth for a few seconds.
4. Then check if the dent has risen and repeat the process if necessary.
The heat and moisture cause the particleboard to swell slightly, helping the dent to somewhat lift.
Caution: If the coating is damaged, this can cause discoloration or further damage!
If this does not help, I suggest using wood fillers or special repair kits for furniture surfaces. Some kits include pastes in various wood tones that can be sanded and varnished afterwards.
I’m curious: how deep are the dents and have you tried experimenting on a less visible spot?
Maybe you can also share how large the affected areas are?
LENNAU
9 Jul 2015 19:45
Hello moli5,
I find your question very practical, and thanks to reybo, you’ve already received a great guide! I would like to add some basic information that might help you choose the best method for your situation.
Billy shelves often have edges covered with a plastic edge band or are slightly rounded. This means the surface at the edges is particularly sensitive and cannot simply be "swelled" back like solid wood.
reybo schrieb:
If the melamine foil is intact, trying to roll out or steam the dent will be difficult.
That’s true, and that’s why I recommend checking whether the dent is only compressed or if the surface is already cracked before using any heat method.
If there are small scratches or cracks, you can mask the area with soft wood repair pencils (available at hardware stores) in a matching color. These pencils are easy to use and achieve good results.
Regarding prevention: I personally protect the edges with edge guards or thin foam strips, especially in high-traffic rooms where the risk of impacts is higher.
Also, I recommend protecting the edges with cardboard or blankets during transport or when moving the shelves.
I hope this helps! :-) If you want, I can also send you links to the repair kits I often use.
reybo
10 Jul 2015 08:23
LENNAU schrieb:
I personally often protect the edges with edge protectors or thin foam rubber strips
That’s an excellent tip! Edge protection is especially effective for Billy shelves since they are often placed in high-traffic areas.
I’d like to add that when using the heat method, it’s important to either keep the iron moving or avoid staying too long on one spot to prevent discoloration or damage to the surface.
moli5 schrieb:
Maybe there are home remedies or DIY tricks to remove the dent or at least conceal it?
Besides ironing, there is also the technique of carefully working the dent out using a damp sponge and applying considerable pressure with your fingers, as long as the dent isn’t too deep.
If that’s not possible, you might also consider replacing the damaged shelf, since Ikea often sells replacement parts for their shelving units at a reasonable price.
How large are the dents exactly? That would help determine whether the effort is worth it or if replacement is the better option.
