ᐅ How can I repair damaged Ikea Metod drawer fronts?
Created on: 26 Jan 2022 18:37
felixpo
felixpo
26 Jan 2022 18:37
I have some damage on my Ikea Metod kitchen drawer fronts, mainly scratches and small dents on the white high-gloss surface. I’m interested in the best way to repair or touch up these fronts without having to replace them entirely, which would be expensive.
I’ve considered whether special repair kits for laminate or plastic surfaces might work, or if it’s better to gently sand the damaged areas with fine sandpaper before treating them. Maybe someone here knows a reliable technique or good materials (fillers, paints, or polishing agents) that work especially well for Metod fronts, particularly because of the high-gloss finish.
It’s also important to me that the repair is discreet and doesn’t leave any visible seams or color differences.
Are there any tips for fixing damaged edges or chipped spots as well?
Thanks in advance for your help!
Tobias
26 Jan 2022 19:04
For small scratches, a special furniture touch-up pen matching the color is often helpful. For dents, you can use epoxy resin, which is then sanded smooth and painted. High gloss finish can be achieved by very fine polishing with suitable pastes. Important: Clean everything thoroughly beforehand.
giabau
27 Jan 2022 09:22
Hello felixpo,
In response to your detailed question, I would like to provide a brief guide on how to repair damaged Ikea Metod drawer fronts without spending a lot on replacement parts.
1. Cleaning: First of all, thoroughly degrease the front using a mild cleaning agent. Dirt or grease will prevent good adhesion of repair materials.
2. Light scratches: For superficial scratches, I recommend using a special plastic or furniture polishing paste, which you gently rub in. This minimizes scratches without damaging the surface.
3. Deeper damage and dents: In this case, a two-component filler or epoxy resin is recommended. Use it to fill the damaged area. After it fully cures, sand the surface smooth with fine sandpaper (e.g., grit 320 to 600).
4. Painting: Since Metod fronts often have a white high-gloss finish, matching the exact color tone is difficult. I suggest a color-matched acrylic spray paint or paint from a tube suitable for plastic. Apply several thin layers and allow to dry thoroughly.
5. High-gloss finish: Finally, you can gently treat the painted area with a fine polishing paste (car paint polish often works well) to even out the gloss.
6. Edges: Chipped edges can be carefully filled with a thick plastic adhesive or repair filler. Again: sand and paint.
Potential mistake: Using too coarse sandpaper can damage the finish, so proceed carefully and use progressively finer grits.
In summary: The combination of cleaning, filler/epoxy, fine sanding, appropriate paint, and polishing often yields good results. For visible front surfaces, a delicate touch is required.
Good luck!
baupau
27 Jan 2022 10:13
I would definitely fill it with a plastic putty knife, then sand it smooth and finally apply a matte finish paint. Achieving a high gloss is difficult without professional spray equipment. It’s better to go with matte if you don’t want it to be perfect.
JONSON
28 Jan 2022 21:47
giabau schrieb:
Since Metod fronts often have a white high-gloss foil, it is difficult to match the exact color tone.
This is a crucial point. I would also like to point out that Ikea Metod fronts usually have a melamine coating on a particle board. This makes repainting difficult because the paint does not penetrate the material but stays on the smooth surface.
In addition, repair attempts involving sanding should be done very carefully, as the thin layer is often quickly scratched and the underlying wood becomes visible.
Sometimes it is better to replace damaged fronts if the damage is widespread. For small repairs, the described method (filler + fine paint + polishing) works well but requires patience and careful work.
A tip: mix some white into the repair material that matches the foil, and work in several layers to minimize color discrepancies.
