DALUDOVIC2 Jul 2023 08:37Hello everyone, I currently have a problem with my IKEA Hemnes doors, which I bought a few years ago. Several doors have damaged edges and surfaces â in some cases, the veneer layers have chipped off or swollen due to moisture. Since I do not want to replace the doors completely, I am interested in proven repair methods to at least restore the Hemnes doors visually to a good condition.
I would like to know which materials and tools you recommend for repairing damaged veneer and swollen wood edges on Hemnes doors. Are there specific fillers, paints, or repair kits that work particularly well? How do you handle surface preparation and the subsequent steps to ensure the repair is as durable as possible? Additionally, I would appreciate any advice from those who have experience with the typical wood finishes of Hemnes â solid wood with a white lacquer coating.
Thank you in advance for your tips and tricks!
Hello DALUDOVIC,
Thank you for your detailed question â that already provides a very good basis to assist you more effectively.
The Hemnes doors are known to be made of solid pine wood, usually with a coating that does not always penetrate deeply, which can lead to the problems you described when exposed to moisture. For chipped veneer or paint, I recommend the following repair process:
- First, carefully remove any loose veneer pieces, for example, using a utility knife.
- Sand the surface, but not too deeply â only down to the solid substrate. This will ensure good adhesion for the repair materials.
- To fill chips or damaged edges, wood filler or repair compounds (preferably water-based, matching the wood color) are suitable. These can be sanded and painted over easily.
- After the filler has dried, sand the surface finely (grit 220 or higher).
- For painting: a matte or satin acrylic paint with a water base is better suited than solvent-based paint, as it shrinks less and does not damage the wood grain.
- Apply several thin layers, allowing each to dry thoroughly.
Proper preparation is especially important to prevent the final result from looking uneven or being easily damaged again.
If you are dealing with moisture, you should also check whether the doors can dry properly and are not constantly exposed to a damp environment.
I hope this helps you so far. If you have more specific questions about color matching or the tools to use, just let me know!
TRADI schrieb:
For painting: A matte or satin acrylic water-based paint is better suited than solvent-based paint, as it shrinks less and does not damage the wood grain.I would like to add to that: Especially with Hemnes doors, which typically have a white finish on pine, it is essential to choose the right paint.
A high-quality acrylic or polyurethane water-based paint in white, specifically designed for furniture surfaces, is recommended. Make sure the paint is fully opaque to ensure a uniform finish. The preparation is best done as follows:
- Remove the door and lay it flat so you can carry out all the work under controlled conditions.
- Treat damaged areas carefully with a fine craft knife and sandpaper (e.g., 180 grit) until all loose material is removed.
- If the edges are swollen, for example due to moisture, gently sand down to the firm wood. You can also apply wood glue if the wood fibers are swollen to stabilize the structure.
- Use wood filler or repair compound suitable for light wood species. Tip: work in several layers to achieve a smooth surface.
- After drying, sand the surface smooth with fine sandpaper (240 grit or finer).
- Donât forget to remove dust, ideally with a damp cloth or a special paint tack cloth.
- Apply paint in thin layers, lightly sanding between coats with very fine sandpaper (320 grit or higher) and cleaning each time.
I am still wondering: How severe is the damage exactly? Are the doors still fully functional, or is the problem mainly visible on the surface and edges? That could influence whether a repair will suffice or if a complete replacement should be considered.
If needed, I can also provide tips on achieving a perfect color match, as this is often one of the biggest challenges with white finishes.
DALUDOVIC3 Jul 2023 07:29kulau schrieb:
Iâm still wondering: How severe is the damage exactly? Are the doors still fully functional, or is the issue mostly visible on the surfaces and edges?Thank you for your detailed explanation, kulau. Regarding your question: The doors still close and function perfectly, which is important to me. The damage is mainly found at the bottom edge of the doors, where they often come into contact with moisture or minor mechanical wear. The veneer layer has chipped off in several spots, and there are swollen edges that I will probably need to sand down. The biggest challenge I see is achieving a repair that is as inconspicuous as possible and well matched in color to the existing white tone of the doors.
The wood structure is still stable, and I donât believe a complete replacement of the doors is necessary as long as the repairs are done carefully.
I would be interested to know how you deal with the color tone on white Hemnes doors, since the paint can yellow slightly over the years, and new coats of paint usually appear lighter. How can one best match the color without it looking patchy?
DALUDOVIC schrieb:
Iâm curious how you deal with the color tone of white Hemnes doors, since the color can yellow slightly over the years and new paint layers usually appear lighter.Thatâs a great point youâre raising, as this particular color tone often causes frustration when making repairs.
My advice for color matching is to follow these steps:
- Apply test paint to a hidden area (e.g., inside edge or back of the door) and evaluate after it dries. This gives an idea of how the color will look.
- Due to yellowing, sometimes it helps not to use pure white paint, but a lightly tinted acrylic paint that matches the original shade exactly. Color samples at hardware stores or paint mixing stations can be very helpful.
- After painting, gently sand the surface with very fine sandpaper (e.g., grit 400) to soften the transition.
- Finally, a matte clear coat can help unify the surface appearance and reduce the shine differences between the fresh paint and the rest of the door.
If youâre repairing several areas, be sure to paint the entire door surface lightly to avoid noticeable patches. This usually results in a more harmonious finish than spot repairs alone.
I hope these tips make the work easier for you. Patience really is the key here!
