Hello everyone, I have a Malm nightstand from IKEA with some chipped paint spots. The areas are relatively small, mostly on the edges and a few flat sections. I want to repair it as discreetly and durably as possible so it does not peel again quickly. My questions are: Which materials (type of paint or suitable repair kits) are best for the repair? How should I prepare the surface to ensure good adhesion? Do I need to sand, prime, or apply multiple layers? Are there any special techniques or tools to achieve a smooth and even finish? I would appreciate practical tips or experiences with the Malm nightstand, as it seems there are different types of paint used. Thanks in advance!
For repairing chipped paint spots on IKEA Malm nightstands, I recommend the following steps based on technical knowledge and experience:
1. Surface preparation: Carefully remove any peeling or loose paint using fine sandpaper (grit 240 to 320). It is essential to remove dirt and all loose material so that the new paint adheres well.
2. Cleaning: Clean the area afterward with a slightly damp cloth to remove dust and grease—using isopropanol can help ensure a grease-free surface.
3. Priming: Depending on the size of the damaged area, apply a thin layer of primer to improve adhesion and even out uneven spots.
4. Paint application: Since the Malm nightstand is typically coated with melamine resin or a foil finish, a conventional acrylic paint from a craft or home improvement store is usually sufficient. It is important to use paint in the matching color. Ideally, use small repair pens or brushes to allow precise work.
5. Final sanding: After the paint has dried, lightly scuff the area with very fine sandpaper (grit 600–800) and, if necessary, apply another thin coat. Note: multiple thin layers produce better results than one thick layer.
6. Topcoat: Optionally, apply an additional protective layer using furniture varnish or clear coat for increased durability.
Summary: Clean the surface, remove loose parts, apply primer if needed, then several thin layers of color paint, and finally seal. This prevents paint from chipping off again later. If the areas are often subjected to mechanical stress, consider adding a small protective edge with transparent edge protection.
Hope these steps help.
Donar34 schrieb:
It is important to use paint in the matching color.In my experience, this is exactly the key point for a precise repair of Malm furniture surfaces! Therefore, I would like to go into more detail regarding color selection and preparation.
Malm furniture usually has a slightly textured foil surface or a melamine resin-coated MDF board, which is not treated like real solid wood with transparent varnishes. The paint is therefore more of a close match, for example in the color "white." Different batches can vary slightly in color.
My tip: First, test a small amount of paint on an inconspicuous spot. Hardware store or model-building paints (acrylic or enamel) are suitable, as long as they adhere well to MDF and plastic. You can also look for exact IKEA repair kits or touch-up pens, which often come closer to the original color.
Preparation should be as follows:
1. Carefully smooth the chipped area mechanically with 320-grit sandpaper to avoid leaving sharp edges.
2. Degrease with alcohol or spirits to ensure good paint adhesion.
3. For larger areas, apply a primer that improves the paint’s adhesion later.
Apply several thin coats of paint during the process and allow each layer to dry thoroughly in between. This way, small imperfections can be easily corrected if the surface looks uneven.
A small detail: If desired, you can simulate the texture by lightly dabbing or using a fine-texture roller to better match the foil appearance.
Finally, seal with a satin-matte varnish to give the repaired spot a uniform gloss, matching the original finish.
How large are the chipped areas exactly? This greatly influences the choice of repair technique.
I understand that chipped paint spots on the Malm nightstand can be really frustrating. Especially when you want not just a quick fix but a lasting solution, it can quickly feel overwhelming.
What has always helped me is to be patient and approach the repair step by step. Even if small mistakes happen along the way – that can happen to anyone 🙂 I think it’s important not to put too much pressure on yourself and to continue appreciating the nightstand despite the repaired areas.
I also think that’s a great tip! Sometimes a small unevenness is hardly noticeable and doesn’t really bother. The key is not to look too closely 🙂
Mutan, how large are the damaged areas? Have you already tried to prepare anything or have you just started? I’m happy to share my own experience of how I repaired a similarly painted nightstand if you like!
Parbo schrieb:
The texture can be simulated with light dabbing or a fine-textured roller surface
Mutan, for a quick and effective repair:
1. Remove loose paint residues.
2. Sand with 240-grit sandpaper.
3. Wipe clean with alcohol.
4. Use a repair pen in the matching color.
5. Let dry and apply a second layer if needed.
6. Optionally, apply clear coat for better protection.
This is the fastest method, which usually holds up well.
