ᐅ How do I repair chipped edges on IKEA BESTA units?
Created on: 9 Apr 2020 08:17
karpar
karpar
9 Apr 2020 08:17
Hello everyone, I have noticed some small chips on the edges of my IKEA Besta sideboard. Since I still consider the piece to be in good condition and don’t want to simply replace it, I’m wondering how to properly repair these chipped edges. It’s important for me to find a solution that is durable and visually as unobtrusive as possible.
The edges are not very wide and are probably either veneer edges or painted edges. Does anyone have experience with suitable materials or techniques to restore such damage neatly? What tools are needed, and are there any special preparations required before starting the repair?
I’d appreciate practical tips or even step-by-step instructions, so I know what really works and what to pay attention to.
LANICOLE
9 Apr 2020 09:41
Hello karpar,
I can gladly provide you with a structured approach for repairing chipped edges on IKEA BESTA furniture. Generally, these edges are made of melamine or foil, which are only somewhat suitable for treatment with conventional wood repair kits. My advice:
- First, thoroughly clean and dry the edge to ensure no dirt interferes with adhesion.
- For small chips, special repair pens or markers designed for furniture edges work well. These usually come in various shades matching wood finishes or white paint.
- If the chips are larger, you should use wood filler or specialized plastic fillers like acrylic, as these are flexible and durable.
- After drying, smooth the area with very fine sandpaper (e.g., grit 240 or finer).
- Then you can touch up with suitable edge paint or lacquer to blend the color transitions.
Make sure not to use sandpaper that is too coarse, as it can damage the surrounding surfaces. It is also advisable to lightly roughen the repair area beforehand to improve adhesion of the paint or filler. If you want, I can provide more details on products or specific application techniques.
Phillipkau
9 Apr 2020 12:03
In addition to LANICOLE’s comments:
Chipped edges on IKEA BESTA furniture are often not just a cosmetic issue but can also compromise the moisture barrier function of edge banding films. Therefore, for larger damages, I recommend considering not only cosmetic repair using filler putty but also sealing the edges with specialized edge-sealing varnishes.
If the damage is very extensive, having a professional reapply a new edge banding film can be a good option. Self-installation is only advisable if you have the right tools, such as an edge banding machine and a heat gun.
For smaller damages, wood repair kits from hardware stores that contain polymers are very effective.
Tools:
- Sandpaper (various grits)
- Putty knife
- Repair filler or wood putty
- Repair pens/markers
Example:
- Fill small defects with putty using the putty knife, smooth out, let dry, sand, then touch up with color.
Jeanbar
9 Apr 2020 14:59
Hello karpar,
I have encountered similar issues with my BESTA furniture and can confirm that careful preparation is essential. It is important to gently remove any loose or chipped remnants without causing further damage.
I have had good results using a white acrylic paint, which is available in small tubes. After applying it with a fine brush, the paint can be sanded smoothly once fully dry, making the edges barely noticeable.
Repeatedly applying thin layers and sanding in between produces excellent results, especially on light-colored edges. However, you should allow enough time to ensure the repair area ultimately blends seamlessly with the undamaged surface.
If you have any questions about specific steps or materials, I’m happy to help!
enrique7
9 Apr 2020 18:22
I would like to point out critically that many repair tips focus on appearance, but often overlook long-term stability.
Phillipkau schrieb:
For minor damage, wood repair kits from hardware stores that specifically contain polymers are very suitable.
Such repair kits can indeed help fill in defects; however, some polymers react adversely with melamine films or particleboard, causing swelling or delamination of the surface.
Therefore, I recommend checking before a repair whether the edge is actually just a film or rather a resin coating. For a professional repair, having the edge refinished by a cabinetmaker could also be considered, especially for heavily used furniture.
What are your thoughts on this?
Declan55
10 Apr 2020 08:05
Hey karpar, don’t worry, this kind of thing can be fixed quickly!
I once used a repair kit that included wood filler and matching touch-up markers. With that, I was able to nicely cover several small dents on the edges of my BESTA furniture within one day!
What worked really well for me:
- Lightly sand the edges,
- apply the filler,
- once dry, sand carefully,
- then go over it with the touch-up marker.
This really makes a big difference visually!
Go ahead and give it a try! My result looked almost like new. Just try it out and roll out the carpet 😉.
