ᐅ How can I repair chipped edges on IKEA Besta units using simple methods?
Created on: 3 Feb 2015 10:17
Parjames
Hello everyone, I have a small problem with my IKEA Besta furniture: some edges have chipped coatings, which not only looks unattractive but also exposes the sensitive surface underneath. Since I don’t want to replace entire parts right away, I’m wondering how I can repair these chipped edges myself using simple methods.
Ideally, I’m looking for a method that doesn’t require special professional tools, mainly using materials that are easy to find at a hardware store or even already available at home. Does anyone have experience with suitable fillers, wood glues, or paints that adhere well to these IKEA particle boards with melamine coating? Are there any particular tips or tricks to make the repair as discreet and durable as possible? I would appreciate any detailed instructions or advice!
Parjames
5 Feb 2015 14:55
chentan schrieb:
- Repair film is applied to the damaged area using an iron or heat gun. It is important that the surface is thoroughly clean, free of grease, and dry.
Using an iron sounds good; I’ve done that before for laminate flooring. However, kitchen and Besta surfaces are not identical, so I’m concerned about adhesion.
chentan schrieb:
How intact are the surrounding edges? Are you planning to repair multiple spots or just one?
In fact, there are several spots across two Besta units that are used daily. At least three corners have chips around 2 cm (1 inch) plus some minor abrasions. I’m looking for a more permanent repair, also visually appealing, ideally using materials that blend in well and adhere properly to melamine surfaces.
Maybe someone can recommend specific brands or products based on experience with melamine resin-coated particleboard.
biel33
5 Feb 2015 16:07
I completely understand how frustrating chipped edges on Besta cabinets can be. I had several spots myself and started with wood filler, which initially turned out too brittle. What finally helped me was a combination of the following steps:
- First, remove small imperfections with fine sandpaper.
- Use a flexible furniture repair filler specifically designed for coated surfaces.
- After drying, gently smooth the area with fine wet sandpaper.
- Then, I purchased a special melamine touch-up paint and applied it in several thin layers.
For me, the key was patience—working in multiple steps and sanding the surfaces really smooth. I also recommend treating all the damaged spots at the same time to keep the color and texture consistent.
If you’re unsure, try the products first on an inconspicuous spot so you can judge how well the material adheres and looks. And don’t worry, practice makes perfect!
matthewon
6 Feb 2015 09:56
I often find the whole repair debate to be somewhat overrated. When furniture looks worn in everyday use, a bit of creativity can even turn that into a character feature.
biel33 schrieb:
I can really understand how frustrating chipped edges on Besta cabinets can be.
Yes, sure, but does everything always have to look perfect? You can also simply use color-matched tape and treat it as a design element instead of trying to hide it.
Of course, this is not for those who want everything very neat. But this sounds like many people go into more detail than I consider worth the effort.
For those who want to try simple solutions: wood filler or repair markers are usually more than enough, unless you want to completely replace the front.
janeo
6 Feb 2015 12:23
It’s interesting to see how varied the approaches are here. One aspect I would like to add is the durability of the repair, depending on the material.
EMILIO schrieb:
A repair marker must match the color well; iron-on melamine foil is an option if there is a suitable pattern.
The problem with repair markers and foils is often their lack of mechanical durability in high-stress areas. Edges, in particular, which are frequently opened and closed, tend to suffer.
A much simpler and longer-lasting method is mechanical fixing using an appropriate adhesive combined with filler.
A note on surface texture: Even on particleboard coated with melamine resin, color matching with paint is easier than perfectly replicating the surface texture; the latter might even require a foil with embossed surface.
Therefore, I would recommend focusing on color matching and mechanical stability instead of achieving a perfect original appearance. This is more sustainable in practice.
