ᐅ How can I repair chipped edges on IKEA Besta units using simple methods?
Created on: 3 Feb 2015 10:17
ParjamesHello everyone, I have a small problem with my IKEA Besta furniture: some edges have chipped coatings, which not only looks unattractive but also exposes the sensitive surface underneath. Since I don’t want to replace entire parts right away, I’m wondering how I can repair these chipped edges myself using simple methods.
Ideally, I’m looking for a method that doesn’t require special professional tools, mainly using materials that are easy to find at a hardware store or even already available at home. Does anyone have experience with suitable fillers, wood glues, or paints that adhere well to these IKEA particle boards with melamine coating? Are there any particular tips or tricks to make the repair as discreet and durable as possible? I would appreciate any detailed instructions or advice!
For repairing chipped edges on IKEA Besta furniture, the following combination of steps works best:
- First, gently sand the damaged area with fine-grit sandpaper to remove any loose fibers.
- Then, use a wood filler or polyester filler to fill in the chipped section.
- After it has dried, sand the surface smoothly again with sandpaper.
- Finally, color-match the area using an appropriate paint or a melamine repair pen.
It is important to use a filler that adheres well to furniture surfaces and to avoid using sandpaper with too coarse a grit to prevent further surface damage. A repair pen should match the color closely. Heat-applied melamine foil is an option if a matching pattern is available.
I would like to go into more detail on this topic because repairs on IKEA Besta cabinets often involve mistakes that affect the final result.
First, it is important to understand the exact construction of the edge: IKEA mostly uses particleboard with a melamine resin coating, which is quite thin and does not have a real wood grain. When this coating chips off, ideally not only the colored surface finish is missing but often a small piece of the board itself as well. This makes repairs more difficult than with solid wood.
My tip: Use wood filler specifically designed for furniture, preferably in white or beige, so that it can be more easily painted over after sanding smooth. Before applying the filler, the edge must be carefully dusted off to ensure good adhesion.
It is also important to sand the surface evenly after the filler has dried, as this is the only way to achieve a flat surface. Depending on the size of the damage, I would recommend applying several thin layers of filler rather than one thick layer. This prevents cracking or flaking later on.
I also recommend using spray paint in the matching color or a special melamine repair paint, as these imitate the rough texture of the melamine coating well. If the color does not match exactly, repair markers are a good alternative, but only for smaller areas.
One question for you: How large are the affected areas exactly? This influences the choice of materials.
deoke schrieb:
One question for you: How large exactly are the affected areas? That influences the choice of materials.Thanks for the detailed advice. The chipped edges vary in size, mostly between 1 and 3 centimeters (0.4 and 1.2 inches) wide, often at the corners – sometimes also elongated over 10 centimeters (4 inches) along edges where, for example, children have bumped into them. For smaller spots, I think a repair pen might be enough, but for longer ones, I would need a more durable solution. The surface should look as seamless as possible, also visually.
If that is very difficult with the larger damages, would something like melamine repair film (applied with an iron) be a feasible alternative to filler techniques? What are the pros and cons?
Melamine repair film can be a quick and visually appealing option under certain conditions, especially for longer chipped edges. Some details:
- The repair film is applied to the damaged area using an iron or heat gun. It is important that the surface is clean, grease-free, and dry.
- Before applying the film, the edge should be lightly sanded smooth and any loose debris removed.
- This film is available in only a few patterns, which is the main drawback, as it is difficult to exactly match the surface of Besta.
- The film is thin, meaning that surface irregularities caused by missing material are not fully evened out. For deeper chips, filling beforehand is necessary to provide a level base for the film.
In contrast, filling followed by painting is more labor-intensive but more flexible, as the color tone can be better matched and the surface texture can be slightly shaped.
In short: For severe damage, I recommend filling plus color matching. For smaller, elongated scratches or scuffs, film can be a neat solution.
How intact are the surrounding edges? Are you planning to repair multiple spots or just individual ones?
