ᐅ How do I repair chipped corners on MALM dressers?
Created on: 27 Aug 2021 18:17
Raleman
I have unfortunately discovered chipped corners on the drawer fronts of my IKEA Malm dresser. This is particularly annoying because the edges are the most visible part, and the wood appears to be either painted or laminated. I am now looking for a solution to repair these damaged areas that is as durable as possible, but also easy to do.
Does anyone have experience with discreetly repairing chipped corners like these? What materials and tools would you recommend? Is it better to use putty, wood glue, or special wood repair kits?
It is also important to know whether it is possible to paint or laminate over the repair afterwards, so that it looks reasonably close to the original.
I look forward to your tips and instructions!
jaanda
27 Aug 2021 20:52
In addition to the previous tips, it is worth mentioning that pre-treating the repair area with a cleaning cloth, such as one with isopropanol, is helpful to remove grease and dirt and improve the adhesion of the filler.
For color matching, both furniture markers and water-based paints are suitable, as they are easier to apply and yellow less over time than oil-based paints.
For larger damages, it is recommended to work in multiple layers to accurately recreate the shape.
pinpa
27 Aug 2021 21:18
Aimee schrieb:
Adjust the color using a furniture marker.
That’s a great tip, Aimee! I also like to do this because it’s quick and looks surprisingly good, especially on smaller chips.
If it has a bit of shine afterwards, it almost looks like new. 😉 But always remember: prepare the surface well first, and the finish will come out perfectly.
anken
28 Aug 2021 08:31
From my experience, the durable edge made of plastic or laminate on Malm dressers is often crucial for the longevity of the repair. If the edge is damaged, it is advisable to carry out the repair using epoxy resin, as it adheres well and is highly durable.
For color matching, products with high resistance to abrasion are recommended. Ready-made furniture repair kits from manufacturers such as "Borma" or "wood dowel repair kits" often provide a convenient solution containing all the necessary components.
Cecilera66
28 Aug 2021 10:17
For chipped corners, I simply applied wood filler with a small spatula, sanded it smoothly after drying, and then colored over it with a matching marker. It works well, looks unobtrusive, and doesn't take much time.
dijan
28 Aug 2021 13:23
pinpa schrieb:
If it also has a slight shine, it almost looks like new.
I completely agree. A slight gloss really makes a big difference. Sometimes I even use colored furniture polish in the final step; it nicely hides minor imperfections.
Oh, and small repairs on furniture really save nerves and money – why buy new when it’s easy to fix? 🙂
RETRAVIS
28 Aug 2021 14:55
Raleman schrieb:
Which materials and tools are recommended?
In summary, I recommend:
- Sandpaper with grit 180-240
- Epoxy or acrylic wood filler
- Plastic putty knife for application
- Cleaning alcohol (isopropanol) for surface preparation
- Wood marker or color-matched acrylic paint
- Clear varnish or furniture polish for sealing
Tools such as brushes and fine foam pads are also helpful for the finish.
Good preparation ensures a durable result.
