Hello everyone, I have noticed some small chips on several corners of my Ikea Besta sideboard’s coating. The affected areas are not very large but quite noticeable because the light gray surface underneath is damaged, revealing the wood or particleboard. Has anyone had experience or tips on how to repair these chipped corners as cleanly, durably, and aesthetically pleasing as possible? I would like to know which materials and tools are best suited, whether special fillers or adhesives are needed, and how to best match the color so that the repair is not visible. Any advice on surface preparation or aftercare would also be greatly appreciated. Thanks in advance!
In addition to previous posts, I recommend avoiding standard wood fillers on thin melamine foil, as they can crack. Instead, use flexible repair compounds designed for furniture panels. It is also advisable to avoid solvent-based acrylic paints, as they can cause discoloration on MDF fronts. Always test on small areas to prevent color variations. The clear coat should ultimately be UV-resistant to prevent darkening of the color. A professional touch-up pen from the furniture sector can be a useful addition.
Thank you for the many helpful suggestions! I especially find kulau’s tips on precise preparation and the individual work steps very valuable. I wanted to ask: Do you have any recommendations for particularly well-suited products (brands or types of repair compounds or touch-up pens) for melamine-coated surfaces like those on Besta? Additionally, I’m wondering how to repair the corners at right angles to maintain their shape. I’m concerned that applying too much filler might round off the edges.
ronro schrieb:
Do you have recommendations for particularly suitable products (brands or types of repair fillers or touch-up pens) for melamine-coated surfaces like on BESTA?For repairing melamine-coated furniture, I like to use "Moltofill Power Repair" for small filling jobs. This product adheres well and remains flexible. For color correction, furniture touch-up pens such as the "Edding 950" in various shades work well since they are water-based and provide good coverage.
ronro schrieb:
Also, I’m wondering how to repair corners at right angles so that the shape is preserved.A template can help here — for example, a piece of cardboard placed on the corner edge to prevent the filler from spreading beyond it. You can also apply several thin layers and scrape the filler along the template to keep the corner sharp.
ronro schrieb:
Also, I’m wondering how to repair corners so that they remain perfectly square and the shape is preserved.That’s a valid concern. For achieving a perfect 90° angle, I recommend the following approach:
- Use a small carpenter’s square or a metal or plastic template. Hold it against the corner while applying the filler.
- Apply the filler in several thin layers. Allow each layer to cure fully before sanding it smooth.
- After sanding, check the edges again with the template and make any necessary adjustments.
- For painting, I suggest using leftover paint or sample colors—such as those from Ikea—possibly combined with a primer/sealer for the surface, if needed.
I also recommend practicing the filler application on a similar piece of scrap wood before starting the actual repair to gain a feel for the process.
That all sounds a bit technical, but don’t worry – it’s definitely manageable! 🙂
I just worked slowly, the rounded result didn’t look bad, and I think the main thing is that the raw wood is no longer visible. If it needs to be super precise, then of course a template is the way to go, but sometimes fine sanding and touch-ups with paint are enough. Just be brave!
Here is a brief step-by-step mini tutorial:
1. Clean the surface (isopropanol or mild cleaning agent)
2. Remove loose film and trim edges with a sharp knife
3. Lightly sand corners for better adhesion
4. Apply repair filler using a template in several thin layers
5. Allow each layer to dry thoroughly (about 1-2 hours depending on the material)
6. Sand between layers with fine sandpaper (grit 320-400)
7. Color match using acrylic paints or special touch-up pens
8. Finish with a matte or satin clear coat
Tip: For better color matching, make subtle color tests on a piece of MDF before painting. This way you can better assess tone, coverage, and gloss level.
