Hello everyone, I seem to have come across a broken screw in my Ikea Platsa wardrobe that is preventing further assembly or securing. Specifically, it is one of the small cam connector screws that apparently broke while being screwed in—most likely due to excessive torque or material fatigue.
My question to the community is: What is the best way to repair or safely remove a broken screw in Ikea’s Platsa system? What tools and methods have you found effective in such cases? Should I get replacement screws directly from Ikea, or can standard hardware store parts be used?
I’m looking for practical advice, ideally with tips on how to avoid causing further damage to the wood or fittings. Thanks in advance for your expertise!
nera59 schrieb:
I recommend applying a protective layer (e.g., masking tape) over the panel before treatment to prevent the melamine from chipping. This is an important tip to avoid damaging the surface.
Regarding screw extractors: these tools are specifically designed for stuck or broken screws. They should be used with the appropriate drill bit, as described.
If you don’t have the right tool, another option is to hammer a small nail into the remaining screw and then try to remove the screw with pliers—but this only works if a small part of the screw is slightly protruding.
For Ikea’s own screws, if you need replacements, it’s worth contacting their customer service. They often provide spare parts for free or at a low cost, since these screws are special and can’t be exactly replaced by hardware store alternatives.
In summary, I would recommend the following: Remove the broken screw using a screw extractor if there is enough access; otherwise, try using a small drill along with wood glue and wooden dowels.
If the hole becomes too large, thread inserts (Helicoils) are an option, but they are often not very durable in thin particleboard. For flat-pack furniture, wood glue and dowels are usually the more practical solution, as these pieces are generally not designed for heavy loads.
Replacement screws should be obtained directly from Ikea at the next opportunity, as these ensure the best fit. Remember to clean the hole thoroughly before assembly so the new dowel or screw fits properly.
