ᐅ How can I fix broken screws in Ikea Platsa units?
Created on: 16 Dec 2021 08:23
blazsigi
blazsigi
16 Dec 2021 08:23
Hello everyone, I seem to have come across a broken screw in my Ikea Platsa wardrobe that is preventing further assembly or securing. Specifically, it is one of the small cam connector screws that apparently broke while being screwed in—most likely due to excessive torque or material fatigue.
My question to the community is: What is the best way to repair or safely remove a broken screw in Ikea’s Platsa system? What tools and methods have you found effective in such cases? Should I get replacement screws directly from Ikea, or can standard hardware store parts be used?
I’m looking for practical advice, ideally with tips on how to avoid causing further damage to the wood or fittings. Thanks in advance for your expertise!
Fitigu
16 Dec 2021 09:47
In such cases, I recommend first carefully removing the broken screw using a screw extractor. Ikea Platsa typically uses special fasteners and screws with standardized dimensions, so replacement parts should ideally be ordered directly from Ikea to ensure proper fit.
It is important to avoid causing significant damage to the wood during removal, as this can affect the stability of the cabinet. After removal, it is advisable to clean the hole and, if it has been widened, to repair it with wood glue and appropriate filler material. The replacement screw can then be inserted.
floga
16 Dec 2021 10:15
I understand how frustrating this can be, especially when you are assembling your furniture yourself and then get held up by such a small issue.
The same thing happened to me with my Platsa, and this is how I handled it: Instead of breaking something right away, I took a deep breath, carefully inspected all the screws, and then slowly started to remove the broken screw. Patience really is the key here.
If you’re not sure whether you’re using the tool correctly, you can first try some test drillings in an inconspicuous spot. That might give you a bit more confidence.
pauPierce
16 Dec 2021 13:54
To address the problem properly, I need a few more details: Is the broken screw a metal screw or a wood screw? How deep is the broken part embedded in the material, and can you measure how far it protrudes or how deep it is in the thread?
The approach depends greatly on this, as for screws broken very deep inside, often the only solution is a left-hand drill bit (screw extractor). Important: You should first drill a small hole exactly in the screw remnant using a center drill, which then serves as the starting point for the extractor.
Alternatively, if the screw is broken just below the surface, you can try to remove the remaining part with pliers, provided there is enough of it sticking out.
Also, consider the condition of the surrounding wood, since overly aggressive methods can cause irreparable damage to the material. Are you working with chipboard or solid wood as the base? In the case of Platsa, it is usually chipboard with a veneer.
Please provide these key details so I can create a detailed step-by-step guide.
blazsigi
17 Dec 2021 07:18
It is a metal wood screw, similar to those used by Ikea for Platsa furniture connection fittings.
pauPierce schrieb:
How deep is the broken part embedded in the material, and can you measure how far it protrudes or how deep it is seated in the thread?
The broken part is completely inside the hole, I can only see a flush metal remnant that does not stick out.
The material is panel construction with a relatively thin chipboard carcass and a melamine-coated surface. I would prefer not to damage the surface because it will be visible later.
I have also considered possibly slightly enlarging the hole in the carcass and securing it with wood glue and a wooden dowel or a small threaded insert – but I haven’t tried this myself yet.
nera59
17 Dec 2021 10:37
To provide targeted help, here is a step-by-step guide on how to proceed when dealing with a broken screw stuck flush in wood:
- First, you will need a screw extractor (left-hand threaded extractor).
- Carefully drill a hole in the center of the broken screw using a small drill bit that is 0.5–1 mm (0.02–0.04 inches) smaller than the extractor.
- Gently and straightly screw the extractor into the drilled hole – it should bite into the screw due to its left-hand thread.
- Slowly turn counterclockwise to unscrew the broken screw piece.
Important: Work carefully to avoid damaging the surrounding particleboard. If the drilled hole is too large or the material is brittle, this method may fail.
If the extractor does not work or you do not have this special tool, you can try this alternative:
- Carefully enlarge the hole with a slightly bigger drill bit,
- Then glue in a wooden dowel with some wood glue,
- After drying, use the dowel as a new anchor for a suitable screw.
This way, you avoid damaging the surface coating while still achieving a stable fixation.
I recommend applying a protective layer (e.g., masking tape) over the panel before starting to prevent the melamine from chipping.
