ᐅ How can I fix warped Ikea Metod cabinet doors?
Created on: 28 Aug 2022 09:17
KINKO
Hello everyone, I have a problem with my Ikea Metod kitchen cabinet doors. Some of the doors are slightly warped, causing them not to close properly and leaving gaps in some cases. This mainly affects the doors made of MDF with a foil finish. The deformation is usually visible at the lower corner, where the door appears slightly bulged. My question is: what is the best way to repair these warped doors without having to replace them completely? Are there proven methods to reverse such warping, and if so, what is the recommended procedure? I would greatly appreciate a detailed guide or practical tips that are manageable for someone with basic DIY skills.
LOJOPAR
29 Aug 2022 08:23
Good morning, KINKO! I hope your attempt was successful. If not, here is a small tip: you can also use wooden slats as levers to gently push against the deformation. Place the slats so that they apply even pressure and adjust them gradually. This way, you avoid excessive point loads that could permanently damage the door.
Elias
29 Aug 2022 09:00
I'm curious to hear how it went. Sometimes working with such delicate materials feels a bit like being a surgeon, doesn't it? I'm definitely keeping my fingers crossed.
KINKO
29 Aug 2022 17:49
Update from me: I removed the door and carefully cleaned it with a damp cotton cloth, then placed it on a flat surface and weighed it down with a board and small weights. After about 30 hours, the warping has noticeably decreased, the gap is smaller, and the door closes better. The film still looks intact. I only had to slightly readjust the hinges. Thank you very much for the tips; they really helped!
derrick34
29 Aug 2022 18:10
Good job! Such repairs are often easier than expected.
Dopoki
29 Aug 2022 19:33
KINKO schrieb:
After about 30 hours, the deformation has noticeably decreased
The result matches the expectations for this treatment exactly. It is advisable to monitor indoor humidity levels over the long term to prevent further deformation.
loken
30 Aug 2022 08:14
Great, I’m really glad it worked out. Remember that you sometimes need to manage not only the doors but also the air in the room a bit. 🙂 Wishing you continued success!
