ᐅ How do I fix a dented edge on BILLY shelves?
Created on: 20 Oct 2022 08:31
neogu
I noticed a dented edge on one of the side panels of my Billy shelf from IKEA. It’s the typical kind of dent caused by bumping or pressure, where the surface is visibly bent in that area. The edge isn’t broken but rather pressed in, so the wood or particleboard has a noticeable dent that you can both see and feel.
My question is: What’s the best way to repair this without taking the entire shelf apart or repainting it? Are there any handy methods or special tools that can help restore the edge to a relatively smooth and clean state?
I’d appreciate any practical tips, especially if you have experience with similar repairs or can provide a step-by-step guide.
Thanks in advance!
WARREN
20 Oct 2022 12:12
I would try moisture and heat. Place a damp cloth over the dent and gently iron over it. It takes some time, but this will pull the dent out.
If the surface has a film or laminate, be careful, as it may peel off.
Gofoman
21 Oct 2022 10:37
I think these methods are all quite nice, but honestly: BILLY shelves are affordable, and a small dent hardly adds value. Is it really worth the effort to do something that almost requires professional furniture restoration?
RETRAVIS schrieb:
Replacing the edge is definitely the best way if the dent is very deep or the surface is heavily damaged.
I agree with that. It saves time, and in the end, the shelf looks like new. A bit of filling and ironing is only a halfway solution that will become noticeable at the latest during the next move.
You should consider whether you will keep using the shelf for much longer or if it might be better to just invest in a new one right away.
Hector
21 Oct 2022 11:09
Gofoman schrieb:
BILLY shelves are affordable, and a small dent hardly affects their value.
That is an interesting, though subjective, point. For many users, the shelf also has sentimental value or has been customized.
A dent can definitely be repaired in a stable and nearly invisible way using a combination of moisture, heat, and appropriate filler techniques, without the extra effort being disproportionate.
It is important, especially at the edges, to carefully assess the damage cases and not necessarily aim for a complete replacement.
neogu
21 Oct 2022 14:44
Thanks in advance for the advice!
To add some information: the surface is actually covered with a thin melamine foil, which somewhat delays the effects of heat. The damage is just a dent, with no open cracks or breaks.
What do you think—how many times can you repeat ironing with moisture without damaging the foil? I’m a bit concerned that the foil might swell or peel off.
Also, is there a particularly recommended filler or type of repair putty that is compatible with melamine foil, or would it be better to use a wood filler?
Your assessment would be very helpful!
jeff65
21 Oct 2022 15:33
neogu schrieb:
How often can you repeat ironing with moisture without damaging the laminate?
There is indeed a risk of damaging the melamine laminate when doing this. Therefore, I recommend using short intervals: apply steam for one to two seconds, then lift the iron and allow the surface to cool. You can repeat this up to three times, but if you go beyond that, watch carefully how the surface reacts.
Regarding fillers, there are repair waxes and micro-fillers made of synthetic resin specifically designed for furniture, which are more flexible than traditional wood fillers, especially on laminated surfaces. These are more compatible with melamine because they can fill cracks or depressions without harming the laminate.
Important: After sanding, gently smooth these areas with very fine sandpaper and apply a suitable furniture lacquer or wax to seal the repair.
