I have a somewhat unusual problem: one of the drawers in my IKEA Besta furniture is broken. Specifically, it’s the bottom part of the drawer where the side panels connect to the base. The wood at the joints has cracked, probably due to excessive weight or simply material fatigue.
My question is: what is the best way to repair a broken drawer in IKEA Besta furniture so that it becomes stable and strong again? I would prefer not to replace the entire drawer if there is a way to reinforce the wood effectively or renew the joint.
Which tools and materials should I use for this? Is wood glue sufficient, or would screws or special brackets for reinforcement make sense? Are there any proven tips or tricks to prevent cracks in furniture parts like these?
I look forward to your experiences and advice!
Hello everyone!
I really like this thread because a drawer can be really annoying when it breaks. My advice: Don’t forget to have a little fun while repairing it, so don’t get discouraged!
Wood glue plus screws is always a solid combination. I personally use self-tapping chipboard screws, which are easy to install and hold well.
If you want, you can also add small battens inside; they’re hidden but still significantly improve the stability. Just experiment a bit and don’t apply too much force, and everything will stay secure.
Good luck and hang in there – you’ll have that drawer working again in no time!
gukarsta schrieb:
So I’m planning to use wood glue with clamping pressure and will pre-drill holes before inserting the screws.That approach is basically correct. However, you should also consider the material properties of particleboard: its edge tensile strength is low, and if too many screws are used or they are placed too close to the edge, the overall stability will decrease.
I also question whether repairing the break is truly the best long-term solution. Would replacing the drawer be more sensible in the long run? Especially if you store heavy items, you should consider the risk of recurring breaks.
Additionally, I recommend reevaluating the load distribution within the drawer or possibly using a sturdier container for particularly heavy objects.
How exactly did the break occur? Was it only along the side joint or also through the bottom? Is there any chance the material has swollen due to moisture? That can significantly affect the effectiveness of the glue joints.
