ᐅ How do I remove stubborn stains from Malm surfaces?
Created on: 7 Dec 2016 08:22
tauko
tauko
7 Dec 2016 08:22
Good morning everyone,
At home, I have surfaces from the Malm series by IKEA, specifically the typical coated drawer fronts and table tops. Unfortunately, I have some stubborn stains that, in my experience, are not easily removed by regular dusting or common household cleaning methods. These include dried coffee stains, grease residues, and occasional ink marks that have set into the coatings.
My question is: What is the best way to remove such stubborn stains from Malm surfaces without damaging the coating or the material? Are there any special cleaning methods, specific cleaners that have proven effective, or homemade remedies you can recommend? I want to avoid dulling or damaging the surface.
Thanks for your tips!
U
usteto
7 Dec 2016 09:05
It is best to use warm water with a bit of dish soap and a microfiber cloth. For stubborn stains, carefully try isopropanol, but test it first in an inconspicuous area.
PIN66
7 Dec 2016 10:48
Malm surfaces are typically made of melamine-coated particleboard. While they are quite durable, you should avoid using strong abrasive cleaners or solvents that could damage the surface.
For coffee stains, I recommend a mixture of lukewarm water and a mild all-purpose cleaner. It is important not to use too much water during cleaning, as the particleboard may swell. You can treat stains with a soft sponge or microfiber cloth. In the case of dried ink, 70% isopropyl alcohol can help, but it should be wiped off quickly without letting it sit.
For grease stains, often just a drop of dish soap in warm water is enough to emulsify and remove the grease. Ink stains are more complicated—you can try acetone-free nail polish remover as well, but be careful: always test on an inconspicuous area first, as such solvents can dull the surface.
Finally, the surface should be wiped down with clear water and a soft cloth and dried thoroughly to prevent streaks.
If you can provide more details about the type of stains or the age of the surface, feel free to share them, and I can offer more targeted advice.
SIAURORA
7 Dec 2016 13:14
usteto schrieb:
It’s best to use warm water with a bit of dish soap and a microfiber cloth.
I always find it quite ridiculous how many people casually claim that you can clean EVERYTHING with that. To be honest, these tips are way too general to be truly helpful for dried-in, discolored stains.
Sometimes people rely so much on these minimally invasive methods that they only realize too late that the stains have almost become part of the surface. In my opinion, you shouldn’t hesitate to use stronger methods more often—of course, applied carefully and tested first, but not too timidly. Otherwise, it will never get properly clean.
Here’s how I see it: If you want your Malm surfaces to look like new, you have to clean them more thoroughly and more often. They’re simply not delicate enough to justify endless hesitation.
Pome60
8 Dec 2016 07:09
Hi tauko,
I completely understand your problem! I also had stubborn stains on my Malm dresser. Your approach with gentle cleaning is great, but sometimes you need a bit of extra power 🙂
I’ve had good results using a mild eraser to treat surface stains like ink or dried coffee. Important: press very lightly and then wipe with a damp cloth. It works better than you might expect!
Keep your chin up – it’s definitely not a lost cause! 🙂 Sometimes a small trick makes a huge difference, so just try it out and don’t get discouraged!
SARBLA1
9 Dec 2016 11:53
Hello tauko,
I would like to add to your approach, especially since proper care is very important for Malm finishes to preserve the coating over the long term.
First, you should always perform a cleaning test on an inconspicuous spot to ensure the surface is not damaged. For worn or damaged coatings, often only replacement or re-treatment helps, as the surface will not restore itself.
A good tip is to always wipe stains from the outside toward the center to avoid spreading the edges. For coffee stains, lightly soaking the area with a cloth dampened in water can help loosen the stain before using dish soap. For grease stains, you can carefully try a drop of a mild solvent, such as turpentine substitute, but use it very sparingly.
Ink stains are particularly tricky. Nail polish remover should only be used as a last resort, and if possible, one without acetone.
Finally, I would like to point out that despite all efforts, the material is coated and stains can eventually remain embedded in the surface. Therefore, I also recommend cleaning regularly and promptly to avoid persistent long-term stains.
If you specify which types of stains are the most difficult, I can provide more targeted advice.
