ᐅ How can I remove stickers from Ikea Besta furniture without leaving any residue?
Created on: 2 Aug 2023 14:37
Teo_emreca
Teo_emreca
2 Aug 2023 14:37
I recently bought a Besta shelving unit from Ikea and want to remove some stickers attached to it. Unfortunately, this often leaves sticky residue behind, which not only looks untidy but is also quite difficult to get rid of.
My specific question is: How can I remove stickers from Ikea Besta furniture without leaving any residue and without damaging the surface? What methods and products have you found to work best? I want to avoid damaging the paint or surface finish through harsh chemicals or scraping.
I would really appreciate any tips, preferably with a brief explanation of why this method is safe for the furniture. Thank you!
Leote
2 Aug 2023 15:48
Hi,
the best way is to place a damp cloth on the sticker and let the moisture work for a few minutes. Then you can carefully try to peel off the sticker. For any residue, I usually use isopropyl alcohol or cooking oil, which generally dissolves the adhesive well and keeps the surface intact.
LUISABEL
3 Aug 2023 09:23
Regarding the question of how to remove stickers from Ikea Besta furniture without leaving residue, I recommend the following structured approach:
- First, treat the surface with warm water and a soft cloth to soften the adhesive.
- Then, carefully apply isopropyl alcohol or a furniture-safe adhesive remover. These agents are effective against sticky residues and do not damage the melamine resin coating of the Besta series.
- Mechanical scraping should only be done with a plastic scraper to avoid scratches.
- Test each method first on an inconspicuous area to ensure no damage occurs.
These steps ensure that the surface of the Besta furniture remains clean and undamaged after sticker removal.
warrenka57
4 Aug 2023 10:52
Teo_emreca schrieb:
I want to avoid damage to the paint or surface caused by harsh chemicals or mechanical scraping.
I completely understand, those things can be really frustrating. I once had stickers on my IKEA furniture that were really stubborn and didn’t come off easily at first.
I took some time and started by using warm water to soften the adhesive residue. Then I carefully used an oil-based product, since oil gently dissolves adhesive without relying on strong chemicals.
Sometimes it takes a while, but I believe patience pays off to keep the surface intact. Maybe you can try this and share how it worked for you!
