ᐅ How can I remove stickers from Ikea Besta furniture without leaving any residue?
Created on: 26 Jun 2023 11:37
NIANEAS
NIANEAS
26 Jun 2023 11:37
I recently bought an Ikea Besta cabinet and noticed that some stickers are attached directly to the surface. I want to remove these stickers as cleanly as possible without damaging or discoloring the surface. My question is: How can I professionally remove stickers from Ikea Besta furniture so that no adhesive residue remains and the surface stays intact?
I understand that you can use mechanical methods or chemical agents, but I’m concerned, especially since the surfaces are often laminated and seem delicate. Does anyone have experience with specific methods or suitable cleaning products recommended for removing such stickers from Ikea Besta?
I would appreciate any tips on procedures and products (for example, solvents, tools) as well as any warnings regarding the furniture surface. Thanks in advance!
Jesus9
26 Jun 2023 14:22
Hello NIANEAS,
I know this problem all too well. I understand how frustrating it can be when stickers just won’t come off cleanly. Especially with IKEA furniture, I often worried about damaging the surface if I was too aggressive.
My tip: Start with heat. I’ve often used a hairdryer to gently warm the sticker. This softens the adhesive a bit, making the film easier to peel off. It’s important not to set the hairdryer too hot—use a medium setting and keep it at a safe distance from the surface!
Then, if you carefully lift the sticker with your fingernails or a plastic scraper, it usually comes off in larger pieces, which makes removal easier and reduces residue. If any adhesive remains, I’ve had good results with a little cooking oil or rubbing alcohol—they help dissolve the glue without damaging the surface.
I understand you’re worried about harming the surface. Try the heat method first on a less visible spot. In my experience, it’s the safest approach and probably the least stressful for both you and the furniture.
Keep at it—and let us know how it goes for you!
Dilen
27 Jun 2023 09:17
Hello NIANEAS,
to answer your question: How do I remove stickers from Ikea Besta units without leaving any residue? Since the surfaces of Besta modules are usually melamine coated or laminated, special care is needed to avoid damaging the finish or the laminate with chemicals or mechanical stress.
I recommend a systematic approach in several steps:
- Step 1: Warm the sticker with a hairdryer, as Jesus9 already mentioned, to soften the adhesive. Be sure to keep a distance of about 40-50 cm (16-20 inches) to avoid overheating the surface.
- Step 2: Try to lift the sticker from the edge using your fingers or a plastic spatula. Avoid metal tools, as they can scratch the surface.
- Step 3: For adhesive residues, isopropanol (rubbing alcohol) or a special adhesive remover based on silicone or polyurethane works well, as these are usually compatible with laminated materials.
- Step 4: After using solvents, immediately clean the area with a damp cloth to remove any residues.
- Step 5: Finally, treat the surface with mild soapy water and let it dry thoroughly.
It is important to test the method first on an inconspicuous spot to rule out any discoloration or surface changes.
I have a follow-up question: What kind of stickers are they exactly? Are they labels made of thick paper, plastic film, or handwritten stickers? Have you already tried any products? This information will help to tailor the method more precisely to your situation.
Lukesan
27 Jun 2023 12:03
I agree with that.
In short: use a hairdryer, then gently peel off, wipe off adhesive residue with some isopropanol. Afterwards, clean again with mild soapy water. Avoid metal.
