ᐅ How can I remove stains from Malm wood?
Created on: 2 May 2024 18:07
dorian60
dorian60
2 May 2024 18:07
Hello everyone, I have a question about stain removal on Malm wood surfaces, specifically regarding the IKEA Malm furniture piece I own. I have noticed stubborn stains on the light wood surface, likely caused by spilled liquids such as coffee or red wine. I want to proceed as gently as possible since the wood is partially coated, and I want to avoid any damage or dull spots. Has anyone had experience with effectively removing such stains without harming the wood finish or surface? Are home remedies sufficient, or is it better to use specialized wood cleaners? I am also interested in how much the wood surface can be roughened during treatment before damage becomes visible. Thanks in advance!
nubar
2 May 2024 19:43
The issue with stains on Malm furniture is often that the surface is sealed but sensitive to harsh cleaning agents. I recommend starting with a gentle approach: lightly dampen a soft cotton cloth with warm water and gently blot the stain—do not rub. If this is not enough, you could try a mild soap solution (pH-neutral). It is important to avoid harsh solvents or abrasive cleaners, as these can damage the lacquer finish. For tougher stains, a specialized wood care cleaner or an alcohol-based solvent is usually effective; however, always test the product on an inconspicuous area first.
Josefane
3 May 2024 08:59
nubar schrieb:
I would initially recommend a gentle method
That is certainly a reasonable approach; however, I would suggest considering the type of coating in more detail. Is it really just a paint finish, or could it possibly be a melamine or laminate foil coating? These differ significantly in their resistance to cleaning agents.
It is also worth questioning whether organic stains (coffee, wine) should be treated with simple cleaners or rather with enzymatic cleaners. Some sources recommend oxalic acid for wood stains, but its use carries risks for the surface. One should carefully evaluate what is being used. Does anyone have experience with these methods on Malm?
LOGEMIN
3 May 2024 11:17
A structured approach to stain removal on Malm wood would be as follows:
1. Accurately identify the surface: Malm furniture from IKEA usually has a melamine coating or foil-coated particleboard, not solid wood varnish. This means the surface is relatively scratch-resistant but not chemically resistant to all solvents.
2. Cleaning steps:
- Start with gentle cleaning using warm water and a drop of dish soap, applied with a microfiber cloth.
- For stubborn stains: test isopropanol (rubbing alcohol) on an inconspicuous spot.
- If this does not help, wood care oil can assist in restoring the surface’s natural oils, but be careful to avoid excessive moisture or aggressive acids (such as oxalic acid), as these can damage the coating.
3. Never sand or treat the surface mechanically in a strong way, as this will permanently damage it.
4. After cleaning, wipe the surface dry and, if necessary, finish with a furniture polish designed specifically for foil surfaces.
If unsure, it is best to test a small area first.
V
vin_leo
4 May 2024 13:28
LOGEMIN schrieb:
If unsure, it’s better to test a small area first.
That’s the key! 🙂
I once had a red wine stain on my Malm bedside table and tried a mild cleaner – what actually worked was a mixture of water and a few drops of gentle dish soap. Then I wiped it off with a damp cloth, and that was it. No scrubbing, nothing dramatic, and the piece looks great again. Using too much force usually causes more damage.
If you want, you can apply a little furniture polish or protective treatment after cleaning – it makes the surface a bit more resistant to future stains. 🙂
