ᐅ How can I remove stains from MALM furniture?
Created on: 11 Feb 2019 08:37
rokenu
rokenu
11 Feb 2019 08:37
I recently noticed some stains on my Malm furniture, which mainly consists of light-colored wood-based material with a foil coating. Since I know that using the wrong cleaning products or methods can damage the surface, I am looking for a gentle yet effective way to safely remove these stains.
I am particularly interested in tips for treating water stains, grease marks, or possibly ink stains on MALM dressers or nightstands. Are there any proven home remedies, specialized cleaning products, or professional methods you would recommend?
It is especially important to me that the surface texture and color consistency are preserved. I look forward to your experiences and advice!
LEEJU
11 Feb 2019 09:02
For MALM furniture, I recommend simply using a damp microfiber cloth. For stubborn stains, you can add a small amount of mild dish soap to the water. Avoid using harsh cleaners!
U
usbla
11 Feb 2019 10:55
To remove stains from MALM furniture, always start with the mildest cleaning methods possible.
1. Water stains: Use a slightly damp cloth, possibly with a minimal amount of mild soap solution.
2. Grease stains: Add a few drops of dishwashing detergent to water, then wipe thoroughly.
3. Ink stains: Isopropyl alcohol can be applied carefully, but be sure to test in an inconspicuous area first to avoid damage or discoloration.
The surface is usually made of foil-coated particleboard and is not scratch-resistant. Therefore, avoid mechanical scrubbing as much as possible.
FAZAR
11 Feb 2019 13:29
usbla schrieb:
Ink stains: Isopropyl alcohol can be applied carefully here, but always test first in an inconspicuous area
Exactly, this precaution is essential!
I recommend the following (somewhat more detailed) procedure for stain removal:
1. Surface cleaning: Remove dust and dirt with a dry microfiber cloth.
2. Identify the type of stain: Differentiate depending on the type of stain (water, grease, ink).
3. Water stains: A cloth dampened with a vinegar-water mixture (1:1) can help, but please be cautious as vinegar can be too strong. Alternatively, use plain water.
4. Grease stains: Lightly rub with a dish detergent solution, then wipe completely dry.
5. Ink stains: Apply isopropyl alcohol in very small amounts, but do not let it sit for more than 30 seconds, and immediately neutralize with clean water.
It is important not to leave moisture on the surface to avoid swelling of the laminate or film coating.
What is the current condition of the stains, and which cleaning methods have already been tried?
rokenu
11 Feb 2019 14:07
FAZAR schrieb:
What is the current condition of the stains and which cleaning methods have been tried so far?
Thank you for the detailed post!
The stains are mainly water rings from glasses that were sometimes placed without coasters, and a few smaller grease spots from food. I don’t have any ink stains yet but want to be prepared.
So far, I have only tried wiping with a slightly damp cloth, but the water rings are still visible and the grease spots are not completely gone. I haven’t tried vinegar yet, and I have been cautious with isopropyl alcohol.
Besides cleaning, my main concern is not to damage the matte film surface. Are there any special furniture care products for laminate or film-coated surfaces that you would recommend?
Parbo
12 Feb 2019 09:19
Regarding care and stain removal for foil-coated MALM furniture, I can provide the following detailed information:
Most MALM furniture has a melamine resin coating, which is quite durable but not completely resistant to aggressive agents.
For water stains caused by standing glasses, it is important not only to clean the surface but also to ensure that moisture does not penetrate into the material. Older water stains often appear as light rings.
My approach:
1. Start by using only a clean, soft cloth and lukewarm water.
2. For slightly more stubborn stains, I use a mild solution of pH-neutral dish soap and water, applied with a microfiber cloth.
3. After cleaning, dry the surface thoroughly, wiping again with a second cloth if necessary.
4. If using furniture care products, I recommend special products designed for foil-coated surfaces that do not contain solvents. For example, furniture care sprays that avoid silicones.
If stains remain despite cleaning, you can carefully use fine abrasive pads (very gently and minimally). However, this should be a last resort and requires experience to avoid damaging the surface.
How severe are the water stains exactly? If possible, try testing a small area first with the dish soap solution.
