ᐅ How do I remove stains from IKEA Hemnes wood surfaces?
Created on: 3 Mar 2020 13:27
Bajill
Bajill
3 Mar 2020 13:27
Hello everyone, I have a question that might concern many IKEA Hemnes owners who want to properly care for their furniture: How can you effectively remove stains from the wooden surfaces of the Hemnes series without damaging the finish? I have noticed that simply cleaning with a damp cloth often isn’t enough, especially for dried or deeper stains like red wine or grease, and I want to avoid ruining the wood stain or varnish. Are there any proven home remedies, special products, or specific methods you would recommend? I look forward to your experiences and advice so I can keep my furniture looking good in the long term.
Pome60
3 Mar 2020 14:35
Hey, great question! IKEA Hemnes furniture is really nice, but the wood surfaces sometimes require more care than you might expect. I once had a very stubborn red wine stain on my table and tried quite a few methods. The key is to act quickly because fresh stains are much easier to remove. I recommend starting with warm water mixed with a little dish soap and a soft cloth to avoid scratching the surfaces. For dried-in stains, I’ve found diluted vinegar water to be a gentle and effective option—but don’t use too much, or the surface may get damaged! Always dry the surface thoroughly afterward. If that doesn’t work, you can try a paste made from baking soda and water, let it sit briefly, then gently rub it off. Hats off if it worked! Don’t give up, everyone—often patience and the right tip make all the difference! 😊👍
relupa
3 Mar 2020 15:18
I can easily understand how annoying it can be when stains soak into the wood—especially with Hemnes, which isn’t solid hardwood but rather veneered with a special surface finish. What helped me was being cautious with home remedies because I was worried about damaging the surface even more. That’s why I bought a mild wood cleaner specifically designed for painted or stained surfaces. Although it seemed like extra effort at first, it was worth it. I also want to be honest that with stubborn stains, sometimes the finish can wear off a bit, especially if you scrub too hard. So it’s best to proceed slowly and gently. It’s also important to properly care for the furniture afterward, for example with wood oil or special maintenance products, to keep the surface durable.
draleo
4 Mar 2020 09:12
For targeted stain removal on IKEA Hemnes wood surfaces, I recommend the following based on material analyses and the manufacturer’s care instructions: The Hemnes surface is usually white lacquered pine wood with a protective finish. For stains that cannot be removed with water and soap, mild cleaning agents without harsh solvents are suitable. A proven solution is a mixture of lukewarm water and a neutral dishwashing detergent, applied with a soft microfiber cloth. For stubborn discolorations, I recommend a paste made from baking soda and water, gently rubbed in and immediately wiped off. Afterwards, make sure no water remains on the surface and that everything is thoroughly dried. Maintaining the surface with a suitable furniture wax or mild wood oil can preserve or improve the protective layer. Intensive sanding or aggressive chemicals should be avoided, as they can damage the lacquer layer and make the wood surface vulnerable in the long term.
V
Victor54
4 Mar 2020 10:47
draleo schrieb:
For stubborn stains, I recommend a paste made of baking soda and water, which should be gently rubbed in and immediately wiped off.
That sounds plausible, but I wonder if this method might still damage the finish if you rub too hard or leave it on for too long. I have also read that the surface coating on Hemnes furniture is rather thin, so one should be very careful. Therefore, I would like to know: Are there any scientific studies or manufacturer guidelines confirming which cleaning agents are truly safe to use? I think home remedies are a good idea, but without solid assurance, there is a risk of causing more harm than good.
draleo
4 Mar 2020 11:31
Victor54 schrieb:
I also read that the surface coating on Hemnes is rather thin, so you have to be very careful.
That is correct. IKEA states in its care instructions that abrasive cleaning products should not be used on Hemnes painted surfaces, as these can damage the protective layer.
Victor54 schrieb:
Are there any scientific studies or manufacturer guidelines confirming exactly which cleaning agents are safe to use?
Official manufacturer guidelines recommend mild, pH-neutral cleaners that contain no solvents or abrasive particles and are generally suitable for painted furniture. Baking soda is a mildly alkaline powder and, when used sparingly in a watery paste form, is considered safe as long as it is not applied too aggressively or for too long.
An empirical study in the field of furniture care shows that mechanical abrasion and harsh chemicals can significantly damage surface quality, so mechanical action should always be kept to a minimum.
