ᐅ How do I remove scratches from Malm furniture?
Created on: 3 Feb 2015 14:23
tilusau
tilusau
3 Feb 2015 14:23
Hello everyone, I have a problem with my Ikea Malm desk. Unfortunately, there are several small scratches on the surface that are quite visible upon closer inspection and affect the overall appearance. I understand that Malm furniture is made of coated wood, likely covered with a thin plastic layer, so I want to be careful not to cause further damage to the surface.
My question is: How can I effectively and safely remove these scratches on Malm furniture, or at least make them less noticeable? Are there any household remedies that work, or should I use special care products or repair kits?
I would appreciate tips specifically related to this type of surface, especially the coated Malm furniture, so I don’t accidentally make things worse. Thank you!
Klakar
3 Feb 2015 14:47
For Malm furniture with a coated surface, minor scratches can usually be gently repaired using a white eraser. Furniture touch-up markers in a matching color also work well for slightly deeper scratches. Please avoid using harsh cleaning agents, as they can damage the surface.
TEBILO
4 Feb 2015 09:15
Hello tilusau, thank you for your very precise question! Malm furniture actually has a melamine resin coating, which is quite resistant but can be sensitive to scratches. To remove or conceal scratches on these surfaces, I recommend the following steps:
1. Cleaning: First, thoroughly clean the surface with a mild cleaning agent to remove dust and grease.
2. Assessing the scratch depth: Are these fine surface scratches, or do the scratches go through to the substrate?
3. For fine scratches: A mixture of some toothpaste (non-gel) and water can help lightly abrade the scratch mechanically. Use only a soft cloth and apply gentle pressure. Test this on an inconspicuous area first!
4. For deeper scratches: I recommend special repair kits for melamine surfaces. These often contain a wax paste that fills the scratch and is color-matched. You can find such kits at hardware stores or online. Be sure to carefully wipe off any excess wax paste afterward.
5. Alternative aids: Silicone-based furniture polish can slightly smooth the surface and hide minor scratches, but it does not actually repair them.
My tip: If you want to be absolutely sure, you can carefully work on the spot with a fine abrasive sponge (very fine, e.g., 1000 grit), but this requires experience because it is easy to dull the gloss.
Could you describe exactly how deep the scratches are or possibly what caused them? That way I can provide more targeted advice.
klo40
4 Feb 2015 17:08
TEBILO schrieb:
To remove or conceal scratches on such surfaces, I recommend the following approach
Very clear explanation from you! I would like to summarize it here in a short tutorial so that every member can easily follow:
1. Clean with a mild detergent; avoid using harsh products.
2. Assess the depth of the scratch visually and by feeling with your fingernail.
3. For very fine scratches: use a white eraser, which sometimes works wonders. Alternatively, you can apply a small amount of furniture polish with a soft tissue.
4. For medium-depth scratches: use a furniture repair pen with paint in the matching color, preferably from the manufacturer or a hardware store.
5. For deeper scratches: liquid stains can help, which can be carefully applied with a dropper. Important: apply in several layers and always let each layer dry thoroughly.
Additionally: Avoid using coarse abrasives, as they can damage the plastic coating. This is often critical for melamine surfaces.
Conclusion: It is better to test first and proceed gradually. This way, you have a good chance to repair the damage without causing new problems.
CHRISTOP33
5 Feb 2015 11:52
tilusau schrieb:
How can I effectively and safely remove these scratches on Malm furniture or at least make them significantly less visible?
Hey, those scratches sound frustrating! 🙂 I’m quite familiar with this issue on Malm tables. From my experience, simple household remedies work well: apply a mixture of a little vegetable oil (like olive oil) and lemon juice to a soft cloth and gently rub it over the scratch. This helps to visually reduce light scuffs and adds a slight shine to the finish.
It sounds simple, but be careful: don’t use too much liquid and always be gentle. Often this is enough without needing to buy special products. Good luck, and let us know how it goes!
