I recently noticed some unpleasant scratches on the white surfaces of my Ikea Pax wardrobe. Since these surfaces are melamine-coated, I’m unsure how to best remove the scratches without causing further damage to the coating.
Specifically, the scratches are fairly superficial, likely caused by bags or keys, and have made the typical matte surface look dull and scratched. I want to avoid causing more damage by using harsh products or incorrect methods.
Does anyone have experience with Ikea Pax surfaces? What are the gentlest and most effective methods to repair or polish matte or melamine-coated furniture surfaces? Are there any special care products or home remedies you would recommend? Or would it be better to replace the affected parts?
I would really appreciate detailed and helpful tips and methods. Thanks in advance!
Hello GEGROVER,
Basically, melamine-coated surfaces like those on Ikea Pax units are very sensitive to abrasive cleaners or mechanical treatments. Scratches on such surfaces cannot be completely removed, but their appearance can at least be reduced.
The following approach has proven effective:
- Clean the surface with a mild detergent (e.g., a little dish soap and warm water).
- Then gently polish with special furniture polish products based on acrylic or melamine, which are available at hardware stores.
- For very fine scratches, special repair kits for laminate or plastic furniture can also be used; these usually contain waxes or fillers.
I would advise against using sandpaper or aggressive polishes, as these will further damage the surface.
If the scratches are too deep, replacing the fronts is often the cleanest solution. Ikea sometimes offers replacement parts for Pax units individually.
I hope this helps you.
Sergio49 schrieb:
Scratches on surfaces like these cannot be completely removedReally? I would argue that most people here give up on scratches far too quickly as being 'beyond repair.' Sure, melamine is delicate—but with the right techniques, more is possible than many realize.
What if, instead of standard furniture polish, you try something a bit bolder and gently work with very fine abrasive pads (not sandpaper!), followed by polishing with carnauba wax?
Of course, this requires a careful touch, and you need to be cautious, but just regularly maintaining furniture with wax makes a big difference. I feel that many people are much too quick to write off their own furniture, even though minimal effort can visibly improve its appearance.
I’m curious to hear what others think about this.
I would like to share a simple approach based on my experience for dealing with scratches on Ikea Pax surfaces:
1. Check the condition: Are the scratches only superficial, or are they deep enough to have damaged the melamine coating? Superficial scratches can be identified if the texture still feels intact.
2. Cleaning: First, remove any dirt using a mild cleaning agent and a soft, non-abrasive cloth. This step is important to prevent particles from causing further abrasion during treatment.
3. Treating light scratches:
- For fine scratches, furniture wax or plastic restorer works well. These fill in small scratches and protect the surface.
- Apply the product thinly, polish it in with a lint-free cloth, and remove any excess wax.
4. More extensive damage:
- If the coating is damaged, small areas can be repaired using an appropriate touch-up paint or paint marker (shade white or cream).
- Important: The paint should be melamine-resistant and, after drying, lightly sanded (with very fine sanding mesh) and polished.
5. Prevention and care:
- Regular maintenance with mild polishing waxes keeps the surface glossy and makes scratches less visible.
Common mistakes I often see:
- Using overly aggressive cleaning agents or solvents
- Naively sanding with sandpaper – this often leaves dull spots or causes deeper damage
I hope this gives you clear guidance. If you like, I can also provide specific product recommendations from hardware stores or furniture retailers.
