Hello everyone, I have noticed some unwanted scratches on the laminate surface of my Ikea PAX wardrobe, caused by normal use or accidental contact with sharp objects. Since the surface is not solid wood but a thin laminate on a particleboard, I want to avoid the scratches worsening or peeling off. Therefore, I am looking for effective methods to gently and permanently remove or conceal these scratches. I am interested in both professional products specifically designed for laminate surfaces and proven home remedies. It is also important to me to preserve the appearance as much as possible, meaning no uneven color tones or dull spots should appear. Does anyone have experience with Ikea PAX laminate surfaces and can provide reliable advice on scratch repair? Any help or suggestions would be greatly appreciated.
I would like to go into more detail because the surface of Ikea PAX wardrobes is quite specific. The laminate is generally melamine-coated, which means it is very resistant to scratches, but once they occur, removing them is not always easy.
- First, you should carefully assess the scratches: are they superficial or deep? Superficial scratches can sometimes be very gently sanded down with very fine sandpaper (grit 1000-2000). However, this must be done with extreme caution to avoid damaging the protective layer.
- After that, I recommend using a special laminate repair pen or wax filler stick, which are designed specifically for furniture surfaces. These fill in small scratches well and blend in color-wise.
- Before application, the surface should be thoroughly degreased with a mild cleaning agent to ensure good adhesion.
- Important: test the products first on an inconspicuous area to avoid color mismatches.
If you ask how durable these repairs are, it depends entirely on how the furniture is used. Regular maintenance with furniture polish helps preserve the appearance and protects against new scratches.
I think it’s great that you’re putting so much detailed thought into this, najan8 – it really shows genuine interest in a sustainable solution. I once had similar scratches on an IKEA PAX wardrobe myself and found it quite frustrating how visible they were.
Your mention of home remedies piques my curiosity: some people swear by simple treatments like olive oil or walnut oil to hide scratches. That sounds a bit unusual to me at first, but maybe there are some experiences to share here?
I must admit, I was pretty afraid of making things worse back then, since the surface can’t be sanded down afterward like real wood. Have you ever tried such oils or focused on natural methods?
Very interesting topic! I would like to contribute some technical details that might help to better understand the situation.
Ikea mostly uses a melamine resin-coated surface for PAX laminate, which creates a solid, durable protective layer. This layer is robust but sensitive to mechanical damage such as scratches.
Trying to treat scratches only with household remedies like oil usually results in superficial visual improvements, but does not structurally seal the scratch.
Recommendations are:
- Lightly roughen the scratches with very fine abrasive pads (not coarse sandpaper!)
- Clean with isopropanol to remove any grease
- Use repair wax or laminate repair kits containing waxes or resins that bond with the laminate surface when heated
For deeper scratches, two-component epoxy resins can also be used, but these require craftsmanship skills and careful application.
Could you specify exactly how deep and how long the scratches are? Are they thin lines or actual gouges in the surface?
Filippo schrieb:
Could you specify exactly how deep or long the scratches are? Are they more like fine lines or actual gouges in the surface?Good question, thanks Filippo. Most of the scratches are relatively fine and usually only a few centimeters long. Some are quite superficial, barely noticeable to the touch under a fingernail. However, there are two that are noticeably deeper and have slightly roughened the laminate layer.
I don’t think I damaged the laminate so badly that the underlying material is exposed, but there is definitely a slight rough texture there.
koduga schrieb:
Some recommend simple remedies like olive oil or walnut oil to conceal scratches.I’ve tried that myself, but unfortunately without lasting success. The scratches look a bit darker at first, but after a short time everything looks the same as before.
