ᐅ How do I remove scratches from the surfaces of Ikea BESTA units?
Created on: 24 Mar 2023 14:07
GO-COLLIN
Hello everyone, I have a problem with my Ikea Besta furniture and need your expert advice. There are scratches on the surface that are not deep but visible and affect the uniform appearance. The BESTA surface is melamine-coated, which probably makes repair more difficult. My specific question is: which methods and materials can be used effectively to remove or at least significantly reduce the appearance of such scratches without damaging the melamine coating? Are there any products, home remedies, or special techniques that have proven effective in practice? Thank you very much for your detailed tips!
Gloriagl10 schrieb:
Try using a polish designed for automotive plastic parts to remove scratches.That is an interesting approach. Automotive plastic polishes often contain fine abrasive particles and waxes that can help make minor scratches less visible. However, use them sparingly and with caution, as the formulation of car polishes differs from products intended for furniture and could damage the surface. Always test on an inconspicuous area first!
GO-COLLIN26 Mar 2023 12:21Thank you all for the helpful feedback. To summarize, it seems that:
- Mechanical sanding is not recommended to protect the melamine coating.
- Gentle polishing with appropriate polishes or plastic care products is a good option for light scratches.
- Wax sticks can be used to cover deeper scratches, although the visual result may vary.
- For larger damages, replacing the panels or using original spare parts is the cleanest solution.
I will follow your recommendations, start carefully with polishing, and possibly get a wax repair kit. If anyone has specific product names or experiences with Ikea Besta surfaces, please feel free to share!
