ᐅ How do I remove scratches from MALM furniture?
Created on: 5 Aug 2020 19:23
BOHAU40
BOHAU40
5 Aug 2020 19:23
Hello everyone, I recently noticed some unpleasant scratches on my Malm furniture, especially on the white lacquered surface. The furniture has been treated with care, yet there are visible scratches that really affect the appearance. Now I’m wondering what methods are available to effectively remove or at least reduce these scratches? I’m looking for specific tips that are suitable for Malm surfaces, which are mostly foil or lacquer coatings, and that won’t damage the furniture. Perhaps someone knows reliable home remedies, specially formulated products, or professional techniques? I’d appreciate any help, even if it’s based on experience with similar furniture. Thanks in advance!
Tause
5 Aug 2020 19:54
I always wonder how deep the scratches really are with questions like this. MALM furniture often consists of particleboard coated with foil or painted MDF, so you can’t just sand it down without damaging the material.
BOHAU40 schrieb:
suitable for MALM surfaces, which are mostly foil or paint coatings, and do not damage the furniture
That’s the crucial point. I’d like to know: are the scratches mostly superficial (just on the paint or foil) or deeper? This makes a huge difference in choosing the right method.
Franz
5 Aug 2020 20:12
That sounds really frustrating with the scratches! Especially when you put effort into properly caring for your furniture, it’s disappointing. I have MALM dressers myself and am also thinking about how to handle them gently.
I agree with Tause and would like to ask: How deep are the scratches? Maybe you can use a polishing paste or a furniture touch-up marker if they’re not too deep. I’ve heard that a wax stick can help with minor scratches. Has anyone had experience with that?
BeAndrea
5 Aug 2020 20:45
Hello, I would like to share some basic tips for removing scratches from furniture with laminated or painted surfaces.
In general: For MALM furniture, which often has melamine or laminated coatings, it’s important not to be too aggressive, as this can damage the surface. For very fine, superficial scratches, the following steps are recommended:
1. Gently clean with warm water and a mild dish soap.
2. Then carefully apply furniture polish or special scratch removers designed for painted surfaces (e.g., product XY from manufacturer Z).
For deeper scratches, furniture touch-up markers or wax crayons in matching colors can sometimes help.
Always test any product on an inconspicuous area first to avoid unwanted effects.
I hope this provides a helpful initial overview! 🙂
GU-LAU60
5 Aug 2020 21:01
Scratches on MALM furniture can usually be repaired with a suitable furniture polish or a wax stick from a hardware store. Simply apply the product in the matching color and polish with a soft cloth.
Ernesto
5 Aug 2020 22:07
I would like to take a more technical approach here, as there are often misunderstandings when it comes to handling MALM furniture.
MALM furniture is usually made of particleboard and covered with a melamine-coated foil or lacquer. The foil is a thin plastic layer that protects the core and also determines the appearance. Scratches on this foil usually appear as white lines because the black or white coloring on the surface has been worn off.
With lacquered surfaces, it looks a bit different, since the lacquer is applied and cured in several layers.
Here is my suggested approach:
1. First, assess the depth of the scratch. Using a good magnifying glass, you can check whether it only affects the surface.
2. For superficial scratches, I recommend special polishes for plastics or automotive polish— but only with very fine grit (e.g., 1000 grit abrasive paste) and gentle polishing with a microfiber cloth. Please apply only light pressure and use circular motions.
3. If the scratches are too deep (penetrating into the foil), usually only replacing the affected panel or professional repair kits containing fillers will help. DIY solutions often lead to worse visual results.
4. Wax crayons or furniture touch-up pens are good for slightly improving the appearance, especially with color-matched options, but they only cover superficial scratches.
One important question for you: Are your MALM furniture surfaces lacquered or foil-coated? And how deep are the scratches compared to the overall thickness of the surface? This would help me give better advice.
