ᐅ How can I repair minor paint and scratch damage on Ikea BESTA furniture myself?
Created on: 5 May 2022 08:43
jabrad
jabrad
5 May 2022 08:43
I have some Ikea Besta furniture in my apartment that has developed minor paint and scratch damage from everyday use. Since I prefer not to replace everything or pay for expensive refinishing, I’m wondering how I can repair these small paint and scratch marks myself as simply and effectively as possible, ideally without much effort or specialized equipment.
Specifically, I’m interested in the following points:
- What materials or products are suitable for treating the surfaces of Besta furniture (mostly melamine or foil finishes)?
- Can these damages be repaired with common products like touch-up pens, or are there better alternatives?
- What is the recommended procedure for preparation and treatment to achieve the least noticeable result?
If anyone has experience or can recommend proven methods and products, I would appreciate detailed advice. Tips on how to avoid further damage during the repair process would also be very helpful.
Thanks in advance!
kogudra
5 May 2022 14:12
Hello jabrad,
Regarding your question about removing minor paint and scratch damage on Ikea BESTA furniture, I would like to share my practical experience. The surface of BESTA furniture is usually coated with a melamine resin or laminate, which limits the options for paint or scratch repairs compared to solid wood pieces.
- Paint pens: Generally, furniture touch-up paint pens that closely match the surface color work quite well for superficial scratches. I recommend gently scuffing the affected area first with a fine abrasive pad (~1000 grit) to help the paint pen adhere better.
- Alternative: Wax sticks or repair wax can be a neat and flexible solution. They can be melted in and worked into the scratches, effectively masking them. Unlike paint, this method provides a filling, customizable repair that is less prone to chipping.
- Preparation: Always clean the area thoroughly to remove dust, grease, and loose particles. Light sanding helps improve adhesion.
- Finishing: For a uniform result, gently polish the repaired area after it has dried.
Conclusion: For minor damage, I would initially try wax sticks in matching colors, possibly touching up the color with colored pencils or similar tools. Paint pens make sense if the surface is not laminated; otherwise, the paint may chip off later.
I hope this helps you.
glamo
6 May 2022 09:37
kogudra schrieb:
The surface of BESTA furniture is usually coated with a melamine resin or foil finish, which makes handling paint or scratch repairs somewhat more challenging compared to solid wood pieces.
Correct, at this point I would like to add that Ikea BESTA furniture mostly uses an ultra-thin melamine foil, which is abrasion-resistant but can be easily cut through by deeper scratches. This means the underlying particleboard (MDF or chipboard) becomes visible, and covering this with just surface-level touch-up pens often is not sufficient.
kogudra schrieb:
Wax sticks or repair wax can be a clean and flexible solution. They can be melted and worked into the cracks
Yes, exactly – I recommend getting a special furniture repair kit that contains several wax colors. It’s important to choose the right shade and to carefully melt the wax into the scratches using a plastic or wooden spatula. Afterwards, you should polish the surface with a soft cloth to remove any excess wax.
I would generally advise against sanding foil-coated BESTA surfaces, as this could further damage the foil. A light cleaning with an isopropyl-based cleaner before the repair is recommended to remove grease and dirt.
If the damage is more extensive, replacing individual foil sections can be considered, but this is a more involved task that requires some experience.
If you like, I can provide you with a detailed step-by-step guide on how I repair small deep scratches.
jabrad
7 May 2022 17:05
glamo schrieb:
If the damage is more extensive, you can also consider replacing individual film layers, but this is a more involved process and requires some experience.
Thank you for the detailed advice, glamo. That sounds a bit more complex, but could be helpful for somewhat larger damages. In everyday situations, I usually have minor scratches from the backs of furniture that can happen when moving them against the wall.
kogudra schrieb:
For smaller damages, I would first try wax pellets, each in a matching color, possibly touching up the color with colored pencils or similar tools.
I can easily imagine that combination working well. I assume wax is more flexible than touch-up pens on foil-coated furniture surfaces?
One last question that often comes up for me: How do you ensure that the repaired area blends in as seamlessly as possible in terms of color? Are commercially available waxes and touch-up pens sufficient, or do you sometimes need to custom mix colors? Are there any tricks for finishing so the repair doesn’t look too “new and shiny” compared to the aged furniture?
If anyone has further ideas, I’m very interested. Thanks again for the great help!
