ᐅ How do I remove grease stains from Malm surfaces?
Created on: 24 Aug 2016 09:17
BIBEKLO
BIBEKLO
24 Aug 2016 09:17
I have a rather annoying problem with grease stains on my Malm dressers from Ikea. Despite regular cleaning, some stains remain persistent and penetrate deeply into the surface, so common household cleaners like dish soap often aren’t enough. Therefore, my question to the community is: What proven methods or products would you recommend for effectively yet gently removing grease stains from Malm surfaces? It would be helpful to have tips not only for fresh stains but also for older or dried-in grease marks, especially methods that don’t damage the finish or texture of the surface. Thanks in advance for your expertise!
Samir
24 Aug 2016 11:23
Removing grease stains from Malm surfaces requires a careful approach, as the furniture usually has a coated or lacquered finish that can be easily damaged. My tip: always start with warm water and a mild, grease-cutting dish soap. Use a soft microfiber cloth and wipe gently in circular motions. For fresher stains, this is usually enough.
For older or dried-on grease stains, you can treat them with a small amount of isopropyl alcohol (rubbing alcohol). Be sure to test the product in an inconspicuous area first to ensure the finish does not become dull. Afterwards, wipe well with water.
Avoid harsh cleaners, abrasive powders, or overly abrasive sponges, as these could ruin the surface.
PIN66
24 Aug 2016 14:06
Your request for a thorough yet gentle method to remove grease stains from Malm surfaces is understandable. These pieces of furniture often have a melamine resin coating, which is sensitive to solvents and mechanical stress.
My approach includes the following steps:
1. Preparation: Remove loose dust and dirt with a soft cloth.
2. First solution: Use lukewarm water with a drop of pH-neutral dish soap (not dishwasher detergent or strong degreasers). Soak a microfiber cloth in this solution and gently wipe in the direction of the grain.
3. Stain test: For stubborn grease stains, carefully apply a small amount of isopropyl alcohol or denatured alcohol, but only spot-wise and not over a large area. It is important to test this first on an inconspicuous spot to avoid discoloration or dulling.
4. Mechanical action: Avoid harsh scrubbing or scratching. If the grease does not come off despite cleaning, you can try gently rubbing the stain with a soft eraser (for example, a plastic eraser).
5. Drying and aftercare: Always wipe the surface with a dry cloth after cleaning and inspect it.
I would be interested to know whether your stains are fresh or dried in, and whether the furniture is exposed to direct sunlight or moisture, as this can affect the cleaning approach.
Issac_kla2
24 Aug 2016 18:09
PIN66 schrieb:
I’m curious whether you’re referring specifically to fresh or dried stains
To be honest, I think all the fuss about these stains is exaggerated. A paint finish isn’t an exclusive designer piece – a little bit of patina is perfectly fine, right?
Samir schrieb:
For fresher stains, that usually suffices.
That’s exactly the point: who wants to deal with stubborn, dried-on grease forever on surfaces that are supposedly “potentially” sensitive? Just use some dish soap, or if needed, a mild spirit cleaner – but don’t stress about the details.
When I bring something nice into my home, I want to use it, not constantly handle it like a surgeon with cleaning products. It’s okay to have some stains now and then; that’s what makes life lively! :-)
BIBEKLO
25 Aug 2016 08:45
PIN66 schrieb:
I’m curious whether you are referring specifically to fresh stains or dried ones
Thanks for asking – it actually concerns both: on one hand, a new grease stain caused accidentally by skin contact, and on the other hand, stains about three weeks old that I just discovered. The surface is the white version of Malm and is located in the bedroom, so there is little sunlight and no direct moisture.
Issac_kla2 schrieb:
It’s okay to have stains sometimes, that’s what makes life lively! :-)
That’s an understandable point, but I would definitely prefer a cleaner piece of furniture – especially regarding damage that wasn’t caused by overlooked mess, but seemingly by unclear cleaning practices. That’s why I would appreciate concrete advice to avoid future problems and reduce existing ones.
keelko
26 Aug 2016 10:12
I’m jumping in here briefly because I really like this discussion 🙂
Regarding grease stains on Malm – yes, that can be a bit of a challenge, especially with older stains. I’ve had good results using a mild mixture of water and a little dish soap, just like others have mentioned here. But if the stain is really stubborn, try a drop of olive oil remover (available at well-stocked drugstores) – it’s often gentler on the material than alcohol and works well on grease.
Important: always test on an inconspicuous spot first! And never scrub roughly, or it might end up looking worse than before 😉
Another tip: after cleaning, let it air dry well and wipe the furniture with a dry, soft cloth – this helps prevent unsightly water marks and preserves the surface in the long run.
Overall, I feel the same: a small stain matters less if you love the style of the furniture, so try not to be too strict ;-) But of course, it’s nice to have a well-maintained piece. Good luck with the cleaning!
