ᐅ How can I remove adhesive residue after assembling Malm furniture?
Created on: 17 Jan 2017 08:13
kelau
I recently noticed, while assembling my Malm chest of drawers, that sticky glue residues formed at some of the joints after fitting the individual parts together. Although these glue residues are not large, they are visible and detract from the otherwise clean finish of the furniture. I would like to know: What is the most effective way to remove these glue residues after assembling Malm furniture without damaging or scratching the surface? Which methods or products have proven to be effective for removing these residues thoroughly yet gently? I look forward to your tips!
Hello kelau,
For laminated surfaces, I really recommend being very careful to avoid damaging the protective film.
You can start by trying slightly warm water and a soft cloth – sometimes the adhesive softens and can be removed without using harsh chemicals.
Alternatively, isopropyl alcohol is often effective at dissolving adhesive residues without harming the film. It’s important to apply the alcohol only locally and immediately blot it off with a clean cloth.
Avoid aggressive solvents like acetone or nail polish remover, as they can easily damage the film!
If the adhesive is very stubborn, a special adhesive remover for delicate surfaces from a hardware store might help – but please test it first on an inconspicuous spot.
I hope this helps!
I hope this helps!
Genuan schrieb:
The best way to soften adhesive residue is by soaking it with olive oil.I find that problematic because oil often leaves a greasy film, which can be particularly difficult to remove from laminated surfaces.
A better option would be isopropyl alcohol or specialized adhesive removers that work without leaving any residue. These are also available in environmentally friendly versions.
Have you checked how large the adhesive residues are? Sometimes applying heat, for example with a hairdryer (not too hot!), can help. Is the adhesive thermoplastic? That might influence which removal method to use.
Hey kelau, this is definitely a tricky issue, but don’t worry, with the right techniques you can manage it! 🙂
I’ve often used a combination of a soft cloth, a bit of rubbing alcohol, and some patience for similar furniture. The key is not to rub too hard, or the surface can become dull! Just gently dab and wait.
Sometimes special adhesive removers from the hardware store can help—there are great products that are even suitable for films. Just give it a try and don’t get discouraged, it will work out! Feel free to share what works best for you, as that will surely help others here.
pinbo schrieb:
Is the adhesive thermoplastic? Good question! From what I understand, it is likely a PVA-based wood glue from the factory. Its residues tend to be hard and brittle, not really thermoplastic. Applying heat might damage the laminate, so I would be cautious.
Thanks to everyone so far for the very helpful advice! I plan to start next weekend with isopropanol and very careful mechanical removal and will report back. If anyone has tips specifically regarding the effect of isopropanol on laminated surfaces, please share!
