ᐅ How can I remove adhesive residues from Malm furniture surfaces?
Created on: 1 Jul 2016 08:37
suleiman57
suleiman57
1 Jul 2016 08:37
I have a challenging issue concerning my IKEA Malm furniture: After applying some stickers on the surface, unfortunately, unpleasant adhesive residues remained that cannot be removed with water or simple rubbing. My specific question is: What gentle and effective methods are there to remove adhesive residues from Malm furniture surfaces without damaging the light veneer or painted finish?
I want to avoid scratching the surface or causing unsightly discoloration. Are there any home remedies or special products suitable for this? It would also be helpful if you could share your experiences with their application and effects on the furniture surface.
Thank you in advance for your tips and advice!
giabau
1 Jul 2016 09:12
Hello suleiman57,
your question is very well formulated and easy to understand! I’ll share my experience on how I removed adhesive residue specifically from Malm (or other IKEA) furniture surfaces without causing damage.
1. In general: Malm furniture usually has a melamine coating, which is relatively prone to scratching.
2. Home remedies:
- First, rub the adhesive residue with a soft cloth and some olive oil or baby oil. The oil often softens the glue and makes it easier to remove. Let it sit for 5-10 minutes.
- Then carefully scrape off the adhesive with a plastic scraper or a credit card.
3. If this is not enough, you can apply a small amount (tested first on an invisible spot!) of a solvent-containing product like isopropanol (rubbing alcohol) with a lint-free cloth.
4. Avoid aggressive solvents like acetone, as they can damage the coating.
5. Finally, wipe down with a damp cloth and let it dry thoroughly.
Summary: Never use sharp objects, avoid harsh chemicals, and always test carefully first.
If you want to know more about how to apply the oil exactly or need further tips, feel free to ask!
Islaso
1 Jul 2016 11:05
giabau schrieb:
Rubbing in olive oil or baby oil often helps well.
I can fully agree with that. I once had some pretty stubborn adhesive residue on my Malm nightstand. I was a bit skeptical, but gently rubbing in baby oil actually softened the glue. It’s important to work very carefully afterwards and REMOVE it ONLY with soft cloths and plastic tools. I was worried the surface might become dull or stained, but that didn’t happen.
I understand the need for caution, especially with these light-colored surfaces. So it’s best to start by following giabau’s advice, and if something doesn’t work, ask again here.
If you try to be too aggressive, you’ll cause more trouble than benefit :-)
libar49
2 Jul 2016 07:44
Just my opinion: All the tips about oil and alcohol sound nice, but I think they only scratch the surface of the problem. Why not just use proven adhesive remover products right away?
suleiman57 schrieb:
Gentle and effective methods that do not damage the surface
I find that wording too mild. In my experience, these pieces of furniture are made for light wear and tear, and a little use of specialized chemicals won’t cause damage if applied correctly. The constant fear of discoloration is often exaggerated with cheap furniture made from thin melamine panels.
Still: anyone who really wants to preserve the furniture can’t avoid a bit of risk. Either you remove the adhesive aggressively, or you keep struggling with it forever. That’s not a contradiction, but reality.
If necessary, it can also help to carefully work the surface with very fine sandpaper (400 grit or higher) after removing the adhesive — but of course, it won’t look like new anymore.
What do you think? I’m curious to hear counterarguments.
kaudi
2 Jul 2016 12:28
libar49 schrieb:
Why not just use the proven adhesive remover products?
The idea makes sense, and such products usually work well. However, when dealing with furniture that has melamine or lacquered surfaces, it is essential to check the ingredients carefully! Many common adhesive removers contain solvents that can dissolve or discolor the surface.
Therefore, I recommend using them cautiously, for example by testing in a hidden area first. Alternatively, you can try citrus-based products, which are often gentler.
libar49 schrieb:
carefully work with very fine sandpaper (400 grit or finer) after the adhesive
I would only consider this as a very last resort, since it can damage the decor and dull the surface. So: exhaust the gentler methods first, then use specific products if needed, and sanding only as a final option.
One last tip: a damp cloth between the adhesive residue and the tool can help prevent scratches.
Hope this helps a bit!
