ᐅ How can I remove adhesive residue from Ikea Brimnes furniture surfaces?
Created on: 30 Mar 2022 08:17
Daleo
Daleo
30 Mar 2022 08:17
Good morning everyone, I have sticky residue from stickers on several places of my Ikea Brimnes dressers that do not come off easily after removing the labels. The furniture surfaces are melamine-coated and quite delicate, so I am looking for a method to effectively remove the adhesive without damaging or discoloring the surface. What home remedies or special cleaning products are suitable for this? Are there any tips on how to proceed to gently but thoroughly eliminate the residue? I look forward to your advice and experiences!
BOSULE
30 Mar 2022 09:12
An important point with melamine-coated surfaces is to always avoid aggressive solvents, as they can damage the surface. Therefore, I recommend starting with warm water and a mild detergent, gently working on the adhesive residues with a soft cloth. If this is not sufficient, isopropyl alcohol in a low concentration is often helpful because it dissolves the adhesive residues while being less harsh on the melamine coating than, for example, acetone or nail polish remover. Important: Test on an inconspicuous area before use and proceed with great care.
Cecilera66
30 Mar 2022 10:34
I have had good results using a mixture of cooking oil and baking powder. Let the oil sit, then gently rub with the baking powder paste. Afterwards, wipe down with soapy water. This method leaves no stains behind.
bapar
30 Mar 2022 12:07
As an addition: Removing adhesive residues from melamine-coated surfaces, such as those on Ikea Brimnes furniture, should always be approached systematically. I recommend the following step-by-step method:
- First, wipe the surface with a soft, damp cloth and warm dishwashing water to remove dirt and loose residues.
- Then try to dissolve the residues using a commercially available, naturally based adhesive remover (citrus-based); these are generally formulated to be milder.
- For stubborn stains, carefully apply isopropyl alcohol with a cotton pad and let it sit briefly.
- Gently rub in circular motions without applying pressure to avoid roughening the surface.
- Finally, remove any residues with a damp cloth and allow the surface to dry completely.
Do not use acetone or chlorine-based solvents under any circumstances, as they can permanently damage the surface. It is especially important to test the method on an inconspicuous area first, since melamine-coated furniture can also react easily. I would be interested to know the exact type of adhesive, as well as the amount and duration of adhesion, since these factors significantly influence the best removal method.
Daleo
31 Mar 2022 07:55
bapar schrieb:
I am interested in the type of adhesive as well as the quantity and duration of adhesion, as these factors greatly influence the best removal method.
Thank you for the detailed post! The adhesive residues come from price label stickers that had been on for several weeks. The adhesive is quite stubborn, rather thin but spread over a wide area. The problem is that the adhesive layer leaves a slightly sticky surface even after the sticker is removed, which attracts dust. I am definitely not interested in using aggressive substances, as I want to preserve the surface.
praWarre69
31 Mar 2022 09:21
Hey Daleo, I totally understand, that sticky stuff is really annoying! 🙂 I had the same issue with my Brimnes table, and what worked really well for me was a very mild mixture of warm water and a small drop of dish soap, a cotton cloth, and a lot of patience. It’s best to dampen the cloth, place it briefly over the adhesive residues to let the moisture soften them, and then gently wipe in a circular motion. If you like, you can add a little baby oil or olive oil to the process, which helps soften the residue – but please use only a small amount and wipe it off well afterward, or else it might attract more dust!
Important: Never scrape with sharp objects, as this can damage the melamine surface. I know it’s not the fastest method, but it’s gentle and effective.
