ᐅ How can I strengthen the connection between individual IKEA Platsa units?
Created on: 27 Aug 2020 08:14
leligi
I plan to expand my IKEA Platsa system with several individual units, but I’m wondering about the best way to reinforce the connections between the different modules. I know IKEA provides connector fittings, but over time they seem a bit shaky, especially as the furniture gets larger or carries more weight.
What options are there to make the connections between Platsa units more secure and stable without compromising the appearance or flexibility? Are there any special screws, brackets, or other DIY solutions you would recommend?
I look forward to your tips, experiences, and perhaps advice on tools or materials that are useful for strengthening these connections. Thanks in advance!
Naomige
28 Aug 2020 13:04
nanidra schrieb:
My thought: Why not connect the modules from the inside using a sturdy strip with pass-through holes?
That is actually a very good idea. Especially if you don’t plan to move the piece of furniture often, such a connection can provide significantly higher stability.
You just need to make sure that the strip used isn’t too thick, so the furniture doesn’t sit too far from the wall or suffer visually. Thin multiplex strips are ideal for this.
The strip can then be screwed to each element with short screws, creating a solid unit. This connection is definitely sturdier than the standard IKEA fasteners.
Thanks for the valuable input!
Cecilera66
28 Aug 2020 19:18
Attach metal brackets on the inside, using longer screws if necessary. If desired, additional wooden boards can be used at the back as connecting supports. This noticeably improves stability.
