ᐅ How can I strengthen the connection between individual IKEA Platsa units?
Created on: 27 Aug 2020 08:14
leligi
leligi
27 Aug 2020 08:14
I plan to expand my IKEA Platsa system with several individual units, but I’m wondering about the best way to reinforce the connections between the different modules. I know IKEA provides connector fittings, but over time they seem a bit shaky, especially as the furniture gets larger or carries more weight.
What options are there to make the connections between Platsa units more secure and stable without compromising the appearance or flexibility? Are there any special screws, brackets, or other DIY solutions you would recommend?
I look forward to your tips, experiences, and perhaps advice on tools or materials that are useful for strengthening these connections. Thanks in advance!
Naomige
27 Aug 2020 09:36
Hello leligi,
Your question is very specific, which is great, because the stability of IKEA Platsa individual units is often underestimated. In general, the original fasteners are sufficient for standard loads, but for larger constructions, it is worthwhile to add extra reinforcement.
- Be sure to use metal corner brackets on the inside corners of the modules to stabilize the edges. These can be installed discreetly and increase lateral strength.
- Another option is screws with longer threads that penetrate deeper into the wood. You can widen the original holes and use stronger screws so the connection doesn’t loosen quickly.
- I would not recommend adhesive brackets or construction adhesive for the main connection, as you may want to move the modules later.
- Make sure to fasten all connections at the designated points and align the units properly before screwing them together.
If you like, I can also write you a brief guide on the best way to install these brackets.
Good luck with your project!
tra_nina
27 Aug 2020 12:21
To add to Naomige’s points, I would like to mention the following:
IKEA Platsa modules are designed to be connected using the supplied fasteners (typically metal connectors and screws). If you want to increase stability without making the individual units rigid or affecting their appearance, I recommend:
- Using metal brackets on the inner edges, preferably with countersunk holes for flush screw installation.
- Adding additional screws into load-bearing wooden parts to better handle tensile forces.
- Placing the modules on a level surface to minimize tipping.
Another option is to use elongated holes (slots) to allow for slight movement, but this should only be done by experienced DIYers.
In short: securing the modules with brackets and longer screws offers the best balance between stability and flexibility.
nanidra
27 Aug 2020 15:07
Naomige schrieb:
Another option is screws with longer threads that penetrate deeply into the wood.
That would be the classic approach, but honestly, I find it ironic that especially with IKEA, where so much emphasis is placed on modular systems, the connections are so weak that you have to rely on DIY hacks to reinforce them.
My thought: Why not connect the modules from the inside with a sturdy strip featuring through-holes? Something like a longitudinal strip that you screw into each module.
This does take more effort and isn’t immediately ‘IKEA-style,’ but it creates a truly robust connection in the long run.
Of course, access behind the strip becomes more difficult, but sometimes stability has to take priority over design – or what do you think?
GLAEL
27 Aug 2020 18:43
I simply mounted small steel brackets at the connection points of my Platsa modules, and it worked without any issues. It holds very well. No major DIY solutions were necessary.
tolokau
28 Aug 2020 07:55
A brief guide to stabilizing the connection between IKEA Platsa individual units:
- Step 1: Place the units on a level surface and align them precisely.
- Step 2: Tighten the original screws firmly, but be careful not to overtighten.
- Step 3: Attach small metal brackets on the inside or in inconspicuous spots, using 2-3 screws per connection point.
- Step 4: If needed, use additional wood screws with longer threads to prevent loosening.
- Step 5: If possible, fix a reinforcing strip to the back, which can be secured with screws or brackets.
Common mistakes: choosing brackets that are too small or screws that are too short.
Summary: A combination of the original connection and additional metal brackets significantly improves stability.
