Hello everyone, I bought Malm dressers from Ikea some time ago, which have proven to be very practical in everyday use. However, I have noticed that the drawers, especially with frequent pulling and the weight of stored items, tend to become somewhat unstable over time. The drawer boxes sometimes start to wobble on the sides or no longer feel firmly secured in their frames.
My question is: How can I reinforce Malm drawers to improve their stability without damaging the original structure or undertaking major modifications? It would be great if you have tips on suitable materials, exactly where to reinforce, and whether there are specific strengthening techniques that have worked well with these dressers.
I have fitted drawers made of wood-based panels with metal drawer slides, in case this is relevant for recommendations. I’m also open to suggestions for tools or particular joining methods. Thanks in advance for your help!
Hello Mukau,
I think your question is very relevant because the Malm dresser can sometimes lack stability due to its lightweight construction, especially when heavily loaded.
For reinforcement, I recommend the following steps:
1. Side reinforcement of the drawer walls: Since the side panels are often thin, you can attach long wooden strips (e.g., 12x12 mm (0.5x0.5 inch) pine strips) inside using wood glue and small screws or nails. Make sure they are flat enough so they don’t rub against the drawer slides.
2. Bottom reinforcement: The drawer bottom can sometimes be stressed by the weight. Screw or glue an additional thin plywood sheet as a new bottom panel. Adjust it precisely to the internal dimensions of the drawer.
3. Securing the back panel: Often the back panel is only held in place by being clamped or stapled – here, screwing it to the frame with angle brackets can significantly improve stability.
4. Check the drawer slides: Be sure to check the slides for looseness, as instability is sometimes caused not by the drawers themselves but by loose slides.
In summary: wooden strips on the sides, an additional bottom panel, better securing of the back panel, plus checking the slides – these steps will noticeably enhance stability.
Common mistakes include using strips that are too thick, which block smooth sliding, or too many screws that can split the material. It’s better to use fewer screws, well placed.
I hope this helps! 🙂
nera59 schrieb:
1. Side reinforcement of the drawer walls: Since the side walls are often thin, you can attach narrow wooden strips (e.g., 12x12 mm (0.5x0.5 inch) pine strips) on the inside using wood glue and small screws or nails.I would like to add that you should be careful not to place the screws too close to the edges of the drawer to avoid tearing the chipboard or MDF material. Countersunk screws measuring 3x16 mm (1/8x5/8 inch) are recommended to secure the strips firmly.
nera59 schrieb:
2. Bottom reinforcement: Sometimes the bottom is stressed by the weight. Additionally, screw or glue a thin plywood board as a new bottom panel.Alternatively, you can use a thin sheet of plywood. While multiplex (plywood) is stable, it does increase the overall weight slightly.
Another tip from me is to carefully measure everything before installing the strips or bottom panels, and to close the drawers as a test before screwing in the strips to ensure nothing sticks.
If the drawers already wobble a lot on the slides, it can also help to align the slides precisely using small washers. Screws tend to loosen over time, especially with extended use.
All in all, some craftsmanship and attention to detail are required, but it’s definitely worth it 🙂
Matthewt4825 Aug 2020 13:02Hello Mukau,
I also had the issue with the Malm drawers, which were slightly bowed and therefore felt a bit unstable. I would like to add that it can be helpful to reinforce the drawers internally with brackets or small metal braces.
A practical solution I used was to attach small flat steel brackets (about 20x20 mm (0.8x0.8 inches)) inside the corners of the drawer; these provide strength in the corners that often give way under load.
Additionally, I lightly oiled the sliding surfaces of the metal runners, which results in smoother sliding and less stress on the side panels.
A common mistake with such reinforcements is using brackets that are too large, which then rub against the rails. It’s better to use small, flat models here. Assembly with self-tapping screws works well since the material is relatively soft.
I hope these practical tips help you. If you’re still unsure about the tools needed, just let me know.
I totally understand how frustrating it can be when the drawers start to wobble, even though they haven't been overloaded very often.
That sounds like a practical and sturdy solution that I’d like to try myself. It just makes you feel more secure with the furniture, doesn’t it?
If anyone has tips on how to strengthen the material in a way that is visually subtle or barely noticeable to the touch, I would appreciate any suggestions.
Matthewt48 schrieb:
mounting small flat steel brackets (about 20x20 mm (0.8x0.8 inches)) inside the corners of the drawer; these provide reinforcement in the corners
