ᐅ How can I reinforce Ikea Hemnes furniture to support heavier loads?
Created on: 2 May 2020 08:42
DonpraHello everyone, I have a somewhat specific question regarding my Ikea Hemnes furniture. I use several Hemnes cabinets and dressers in my workshop, but over time I have reached the limits of their load capacity, especially when storing heavier items. Although the furniture has a sturdy design, it consists of relatively thin wood panels and simple joints, so I am specifically looking for ways to reinforce the furniture without completely rebuilding it or buying something entirely new. I am interested in both mechanical reinforcements — for example, additional cross braces, metal brackets, or new screws — as well as ideas for strengthening the joinery, such as gluing or special dowels. Has anyone had experience reinforcing Hemnes furniture or similar Ikea models to consistently support heavier loads? Which materials and techniques have proven effective, and what should I pay particular attention to in order to avoid damaging the furniture? I look forward to your tips and experiences!
stefangla2 May 2020 10:36Hello Donpra, your concern is quite reasonable since the Hemnes series is sturdy but not designed for extreme loads. I would recommend a three-step approach:
- First: Install metal brackets or small steel plates on the weakest joints (usually the corners of the carcass) from the inside. Be sure to use appropriate countersunk screws that won’t damage the surface.
- Second: Insert cross braces made of plywood or solid beech wood across the carcass. This significantly reduces shear forces on the veneer wood.
- Third: Use wooden dowels at the joints in addition, and you can also strengthen the connections with wood glue, which provides a durable bond once cured.
It is important not to overload the original fasteners and especially not to simply use longer screws, as this can cause the material to splinter. Also, regular checks of the screws after a few weeks of use are advisable.
GALENKU schrieb:
I would recommend metal brackets at the corner joints. Thank you for the quick reply! Could you possibly also say how strong these brackets should ideally be? Are simple stainless steel brackets from a hardware store sufficient, or is something more specialized needed? I don’t want the furniture to warp or for the brackets to loosen over time.
Regarding the idea of cross braces – would plywood be better than regular pine wood or MDF? I’m wondering which type of wood best harmonizes with the workable and relatively soft Hemnes wood without causing stress.
Donpra schrieb:
Regarding the idea of cross braces – would plywood be better than regular pine wood or MDF? Hey Donpra, that’s an interesting question! Plywood definitely offers the best combination of strength and flexibility. It warps less, which is great for Hemnes furniture since it sometimes tends to bend a bit under heavy loads. MDF is affordable but usually too brittle, and pine wood can change a lot with moisture – so not the best choice for long-term load-bearing. So: plywood clearly wins here! 😊
As for the stainless steel brackets: as long as they’re made of stainless steel and at least 2-3 mm (0.08-0.12 inches) thick, they will keep your Hemnes pieces solidly in place – no worries, the effort is worth it!
