ᐅ How can I quickly repair damaged Ikea BESTA drawers?
Created on: 26 Jun 2023 08:37
sinzar48
sinzar48
26 Jun 2023 08:37
Good morning everyone,
I have a problem with my Ikea Besta drawers, which have unfortunately developed some damage after extended use. Specifically, I mean both drawers that stick and some loose screws, as well as minor cracks in the material on the side panels of the drawers.
Therefore, I am interested in how I can quickly and effectively repair Ikea Besta drawers myself in cases like this, without having to order large replacement parts or replace the entire drawer.
I am looking for practical tips that help restore the function and stability of the drawers as quickly as possible. Which materials and tools are recommended, what exact steps should I take, and what should I pay special attention to during this type of repair?
Thanks in advance for your help!
Wesley
26 Jun 2023 09:43
sinzar48 schrieb:
How can I quickly and effectively repair Ikea BESTA drawers with this kind of damage myself, without having to order large replacement parts or replace the entire drawer?
Hey, I know this problem all too well – these drawers are quite sturdy, but eventually they can cause trouble.
Here’s a simple guide for a quick repair:
- Tighten screws: Most of the time, loose screws are the main cause of issues. Grab a Phillips screwdriver and tighten all the screws on the sides and back panel of the drawer.
- Jamming: If the drawer sticks, it might be due to dust or dirt on the runners or slides – just clean them with a dry cloth.
- Cracks in the sides: Strong wood glue (preferably fast-drying wood glue) works well here. Press the cracks together gently and clamp them until dry.
- Optional: If there’s still some sticking, you can apply a small amount of silicone spray to the runners – this makes everything slide more smoothly.
In no time, the drawer should be working again without any hassle! And if you do need parts, IKEA often sells individual components separately.
Good luck and don’t worry, it’s usually simpler than you think!
gesar32
27 Jun 2023 11:06
Wesley schrieb:
Tightening screws: Usually, loose screws are the cause of quick problems.
This approach is indeed the first sensible step.
I would like to add:
- Screw connections: If necessary, use a threadlocker (e.g., medium-strength threadlocker) to prevent screws from loosening again.
- Repairing material cracks: Besides wood glue, I recommend using fine sandpaper after drying to smooth transitions and stabilize the repaired area.
- Drawer slides: The rollers in the BESTA system are often made of plastic. Check them for damage. Replacement rollers can be purchased individually and should be replaced if defective.
- Cleaning: Dirt in the guide rails can cause jamming. Clean the rails with a lint-free cloth. Never use oil, as it attracts dirt.
- Tools: Phillips and flathead screwdrivers in smaller sizes, a small hammer, and possibly a set of hex keys are often helpful.
Care and organization are crucial here to maximize the lifespan of the drawers.
BARSAN
28 Jun 2023 17:24
sinzar48 schrieb:
Which materials and tools are recommended, what exact steps should I follow, and what should I pay special attention to for this type of repair?
- Check screws and replace if necessary
- Use wood glue for cracks
- Clean the sliding tracks with a cloth
- Use silicone spray sparingly
- Spare parts can be ordered separately from IKEA
This is usually sufficient.
