ᐅ How can I quickly and discreetly repair chipped edges on IKEA BESTA units?
Created on: 17 Dec 2020 19:27
resulHello everyone,
I have some chipped edges on my IKEA Besta sideboard, especially on the corners. Since I really like this piece of furniture and would prefer to avoid major repairs, I’m asking here: How can I quickly and discreetly repair chipped edges on an IKEA Besta?
It’s important to me that the repair is not only visually unobtrusive but also reasonably durable, especially because the Besta fronts usually have thin plastic or melamine coatings. Are there any practical materials or repair kits suitable for this? And what does the process look like if I want to do it myself without cutting parts off or buying a completely new unit?
I’m looking forward to your tips and experiences!
Hello resul,
your question is very precise, which already means half the success!
To quickly and inconspicuously repair chipped edges on IKEA BESTA, there are different approaches depending on the severity of the damage.
- Filler: For smaller chips, I recommend wood filler or putty designed for furniture. It is important that the filler is easy to sand and forms a hard surface after drying.
- Edge banding: If the melamine or plastic edge is chipped, a thin edge band can be applied with an iron. This is often the simplest way to restore the appearance.
- Color-matched touch-up pens or markers: You can correct small damages with matching touch-up pens from a hardware store. This requires some skill, as the transitions need to be blended well.
Step-by-step suggestion:
1. Clean: Remove stuck dirt or chip remnants.
2. Fill: Fill small holes with wood filler and smooth the surface.
3. Sand: After drying, smooth the area with fine sandpaper (grit 220–320).
4. Apply edge band: Reapply where edges are chipped, fixing it with an iron.
5. Color finishing: Retouch repair spots with touch-up pens.
Could you also specify whether the fronts are solid wood or rather coated particleboard? The extent of the damage is also relevant — are they tiny edges or large chips? That would influence the choice of method.
Best regards, TEBILO
TEBILO schrieb:
For small chips, I recommend wood filler or putty suitable for furniture.I’ll propose a somewhat provocative statement: wood filler is actually overkill for IKEA furniture, which often consists of particleboard or MDF with foil or paper coating, and it tends to result in visible differences in texture and color.
In my opinion, repair kits specifically designed for laminate or plastic surfaces are much better. They create an almost pore-free finish and visually blend in better with the rest – even if you need to spend a bit more time on blending. All the wood-related stuff is usually wasted money and effort in this context.
My advice: try a good two-component plastic filler or repair kit from a furniture store. It’s faster, more durable, and usually looks better than traditional wood fillers. If you want a quick and inconspicuous repair, you should save on the material, not the method.
What do you think?
Matthewt4818 Dec 2020 08:12Hello everyone,
to add to the discussion, I would like to briefly explain why it is so important to first identify the type of existing material. IKEA BESTA furniture is usually not made of solid wood, but rather coated particleboard or MDF panels with plastic or melamine surfaces.
If the edge is chipped, it’s not just the engineered wood that is damaged, but also the surface.
- What often helps very well are edge repair tapes, which come in various designs. Of course, you need to find the right one, but they are usually quick to apply and very durable.
- If the damage is larger, as mentioned before, I would recommend a 2-component filler for plastic. This will give you a surface similar to the original.
- It is also important to carefully match the color using suitable markers or paints. There are so-called furniture paint markers that often offer a much better color match than cheap wood stains.
And very important: always thoroughly clean and lightly sand the surface before repair, so that glue and filler adhere well.
If necessary, feel free to write again with detailed information about the exact damage. By the way, repair materials are available at well-stocked hardware stores or specialty suppliers.
Good luck!
Good luck!
TEBILO schrieb:
Can you also say whether your cabinet fronts are made of real wood or rather coated particleboard? The extent of the damage is also interesting — are they just tiny chips on the edges or larger flakes?Thanks for the helpful responses!
The fronts are definitely not solid wood but more like MDF with a thin melamine coating. The chipped areas are quite small, several tiny corners or slightly chipped edges, but no large cracks or missing pieces.
I would like to act as quickly as possible since these spots are visually unappealing and tend to collect dust. Some very small edges are rough and feel slightly sharp.
Can anyone share from their own experience whether edge banding really looks like new on such minor damage? I’m a bit concerned that I’ll then notice differences compared to the original surfaces. And how well does edge banding adhere to this kind of material?
Thanks again for your insights!
