ᐅ How can I quickly and easily repair damaged IKEA Metod cabinet doors?
Created on: 19 Nov 2022 10:17
TARBEN
TARBEN
19 Nov 2022 10:17
Hello everyone, I have some damaged IKEA Metod kitchen cabinet doors with scratches and small dents on the edges and surfaces. My question is how I can quickly and easily repair these damages at home without having to replace the doors entirely. Are there practical methods or products to simply fix these common signs of wear and tear? I would appreciate tips that require little effort but still deliver a neat result, especially on the white and high-gloss finishes. Thank you in advance!
plopra
19 Nov 2022 10:26
Simply trace over the scratch with a white touch-up pen or furniture repair marker. For small dents, furniture wax or wood filler can help achieve a smooth surface.
SETHBLA
19 Nov 2022 10:42
What often works well with Metod doors is sanding the damaged areas with fine sandpaper, followed by applying a suitable paint for touch-ups. Once dry, it looks almost like new.
MUMENAR
19 Nov 2022 11:13
SETHBLA schrieb:
What often works well with Metod doors is sanding the damaged areas with fine sandpaper and then touching up with a suitable paint.
That might work, but is it really that easy and quick to do? Especially with high-gloss surfaces, sanding can be tricky because it’s hard to match the finish and it can also look uneven. Aren’t there more specialized repair kits or sealants for this? You often hear about two-component fillers or putties that can be sanded afterward – but how practical is that for DIY use if you don’t want to treat the entire surface?
Aimee
19 Nov 2022 11:42
MUMENAR schrieb:
Are there not also more specialized repair kits or sealants?
Yes, there are kits from various manufacturers designed specifically for furniture repairs. They often include fillers combined with touch-up pens and sometimes polishing cloths. For high-gloss surfaces, this is indeed the best approach, although these kits are usually somewhat more expensive and require some drying time.
NUPIN
20 Nov 2022 09:08
Oh yes, I have also repaired such doors at home! 🙂 For me, using a repair kit was brilliant because it includes everything you need. Simply fill the dents with the special compound, let it dry briefly, sand it lightly, and then apply the high-gloss paint pen. The result really surprised me; the doors looked almost like new! So definitely a recommendation from me, even though it requires a bit of patience.
