I have several Malm dressers from IKEA in my apartment, which I mainly use in the bedroom. Due to the slightly higher humidity, especially during the cooler months, I am concerned about potential moisture damage, such as swelling or warping of the surface.
My question: What practical and effective measures can you recommend to protect Malm furniture specifically from moisture damage?
I am interested in both preventive tips (e.g., protective treatments like oils or varnishes) and everyday habits to keep in mind. Also, are there any special considerations regarding the material (particleboard with laminate coating) that should be taken into account to extend the furniture’s lifespan?
Thanks in advance for your help!
valerie-tr schrieb:
Do you already have a regular inspection schedule?So far, only occasionally, maybe checking the furniture lightly 1-2 times per month to see if anything has changed.
I think I will start doing a weekly check to be able to respond quickly if, for example, there is more swelling or new damage.
A product recommendation would be great! And if you have any other easy-to-apply tips, please share them.
To prevent moisture damage to Malm furniture, the following points are essential:
1. The laminate coating protects surfaces, but the edges of the particleboard are usually unprotected. These should therefore be treated with an appropriate edge sealer.
2. Using hygroscopic measuring devices (hygrometers) to monitor indoor humidity is advisable. A relative humidity between 40 and 60% minimizes moisture damage.
3. Moisture peaks, such as condensation on windows, should be avoided by ensuring furniture maintains sufficient distance from walls and windows.
4. General precautions: do not place wet or damp objects directly on the furniture, avoid standing water, and do not use aggressive cleaning with wet cloths.
These recommendations are based on the material properties of particleboard and laminate coating to prevent swelling and related damage.
