ᐅ How can I protect Malm furniture during a move?
Created on: 16 Oct 2019 08:37
kaixra
kaixra
16 Oct 2019 08:37
I am planning to move soon and own several pieces of furniture from the Malm series by IKEA. Since these furniture items are mostly made of veneer-covered particleboard and are quite sensitive to scratches and moisture, I want to protect them as best as possible. I am especially interested in how to properly prepare the furniture for transport to avoid damage to the corners or dirt on the surfaces.
Additionally, I wonder if there are specific packaging materials that are particularly suitable for Malm furniture, or if simple blankets and stretch wrap are sufficient. If anyone has experience with dismantling and later reassembling this furniture, I would also appreciate tips on that topic.
Thanks in advance for your advice!
Laukau5
16 Oct 2019 10:46
Hello kaixra,
I want to address your question as thoroughly as possible because protecting Malm furniture during a move involves some specific details. As you correctly noted, the furniture is made from veneered particleboard, which means the edges are especially prone to chipping, and the surfaces can quickly absorb scratches and moisture.
First, disassembly is advisable to avoid damage during carrying or storage in the moving vehicle. With Malm furniture, this is often relatively easy since the pieces are connected with cam lock screws. It is important to carefully label and store all screws and small parts in clearly marked bags when taking the furniture apart.
Now regarding packing:
- Use moving blankets or thick wool blankets to cushion each individual panel. The padding should fit fully and without wrinkles.
- Then secure the padded parts with stretch wrap to prevent the blankets from shifting or slipping.
- For particularly vulnerable edges and corners, I recommend special foam edge protectors. If these are not available, you can add thicker layers of bubble wrap.
- Avoid placing plastic film directly on the veneered surface, as this can trap moisture in case of condensation and damage the furniture.
One more tip for storage during transport: make sure the furniture is not stored lying flat on hard surfaces but rather kept upright with enough space between items to prevent warping.
Do you plan to completely disassemble the furniture or transport it partly assembled? This also affects the packing strategy somewhat.
Best regards!
lofar
16 Oct 2019 11:22
You should completely disassemble your Malm furniture. Wrap the parts with furniture blankets and secure everything with stretch wrap. Corner protectors for delicate edges are advisable. This way, you avoid scratches and damage.
kaixra
17 Oct 2019 09:15
Laukau5 schrieb:
Are you planning to completely disassemble the furniture or transport it partially assembled?
I intended to disassemble the furniture as completely as possible and then reassemble it. I think this is the safest approach, even though the reassembly takes some time.
Are there any best practices for organizing the many screws? I've often read that keeping them in small bags is effective – but how do you prevent mixing them up? Should you use separate bags for each furniture component, or are there better methods?
Also, does anyone have tips on how to best protect the surfaces of Malm dressers from dents or scratches when stacking the individual panels, for example?
Jonna
17 Oct 2019 11:37
For organizing screws, I recommend a labeled system: for each furniture part, prepare small transparent zip bags and label them clearly (e.g., "Malm dresser left side"). Alternatively, you can use empty, sturdy plastic boxes with dividers to prevent the screws from mixing.
It is also important to keep the assembly instructions handy to make the construction process easier.
For stacked panels, thick moving blankets are essential. You can place a protective layer of thick cardboard or foam between each panel to prevent pressure marks or slight deformations. Also, make sure there are no sharp or hard objects in between.
Condensation can be avoided by keeping the furniture dry during packaging and transport, and by preventing direct contact of plastic sheeting with the surface – as mentioned earlier.
These measures significantly reduce the risk of dents or scratches.
