ᐅ How can I protect IKEA PLATSA furniture from moisture?
Created on: 20 Nov 2020 07:39
Pumo39
Pumo39
20 Nov 2020 07:39
Hello everyone, I have a question where I need your expertise.
I own some IKEA Platsa furniture that I want to protect from moisture. The furniture is partially placed in my hallway and bathroom, areas that are exposed to higher humidity – whether from moist air, occasional splashes, or temperature differences.
I am especially interested in practical measures you would recommend to protect the furniture from moisture damage, warping, or mold growth.
Specifically, I would like to know:
- Which surface treatments or sealants are suitable for Platsa?
- Are there any construction solutions (e.g., spacers, ventilation) to keep moisture away?
- Do you have experience with special protective films or coatings?
Thank you in advance for your helpful responses!
TEBILO
20 Nov 2020 08:56
Hello Pumo39,
Your question is very specific and important because PLATSA furniture is made of wood-based panels, which do not handle moisture well. I will address your points step by step:
- Surface treatment: IKEA PLATSA is usually coated with melamine or a plastic laminate, which provides some water resistance. However, edges are often exposed and vulnerable. I strongly recommend sealing the cut edges with clear varnish or a special edge-sealing product. This prevents moisture from penetrating at the most vulnerable spots.
- Impregnation: There are water-repellent wood preservatives that can be applied thinly. Make sure they do not alter the appearance or remain sticky. It’s best to test them first on inconspicuous areas.
- Practical building solutions: A good idea is not to place the furniture directly on cold or damp floors. Spacers made of plastic or small wooden strips (protected with suitable varnish) create an air gap that improves ventilation. If possible, position the furniture a few centimeters away from walls or exposed moisture sources.
- Protective films can be a double-edged sword: they may keep moisture away from the wood, but very good ventilation is required so that no moisture gets trapped inside.
I would also recommend avoiding completely airtight doors to prevent condensation inside. Regular airing out helps significantly to prevent mold.
In short: seal the edges, create gaps from the walls and floor, and avoid trapped air. I would be interested to know in which specific room (bathroom, hallway?) the furniture is located and whether moisture damage is already present. Then I can offer more targeted advice.
Israel62
20 Nov 2020 09:12
Seal edges with clear varnish, place the furniture on legs or spacers. Do not position it directly against the wall, ensure good ventilation. This way, you avoid moisture damage to PLATSA.
kemeo68
20 Nov 2020 09:25
TEBILO schrieb:
Seal edges, leave a gap from the wall/floor, avoid trapped air pockets.
Well, it almost sounds like IKEA furniture wasn’t designed for damp rooms. All the hassle with sealing the edges—that’s basically an admission of defeat. I’m not expecting furniture to be completely waterproof like an aquarium, but if you’re placing pieces in bathrooms or hallways where moisture is common, there should at least be better factory-applied protection.
Honestly, I find it quite risky to rely on improvised edge finishing and spacers.
Why not just go for solid wood furniture or materials specifically made for damp environments?
Sometimes I wonder if IKEA simply expects customers to replace their products every year when they swell or develop mold.
O
onMarcos
20 Nov 2020 11:37
Hello everyone, to bring some structure to this topic, I’ll summarize the key steps I recommend for protecting IKEA PLATSA furniture from moisture:
1. Edge Sealing:
As mentioned before, the melamine-coated surfaces are quite durable. However, the cut edges absorb moisture quickly. A clear coat (water-based acrylic varnish) that dries quickly and remains transparent is suitable for proper sealing.
2. Create Clearance:
Do not place the furniture directly on the floor, especially not on tiles or cold surfaces. Small feet or pads made of cork/plastic prevent moisture accumulation from below and promote air circulation.
3. Ensure Ventilation:
Even if the furniture is placed against a wall, leave a small gap. This allows air to circulate and moisture to escape.
4. Avoid High Humidity Areas:
Although many pieces look “water-resistant,” PLATSA is not designed for consistently high humidity levels or direct water splashes.
5. Moisture Absorbing Accessories:
In rooms with particularly high humidity (e.g., bathrooms), dehumidifiers or silica gel packs can be helpful.
Important: Clean and dry the furniture thoroughly before sealing.
If anyone has tips for choosing suitable varnishes or advice specifically for rooms with high humidity, I would be interested to hear them.
Timofa
20 Nov 2020 12:01
kemeo68 schrieb:
Why not just choose solid wood furniture or materials suitable for damp rooms?
Well, not everyone wants to put a Viking ship in their bathroom, right? 😄 Joking aside – IKEA furniture is affordable and often quite versatile.
I believe with a bit of know-how, you can make it reasonably moisture-resistant. Of course, if you expect constant rain inside your living room all year round, it gets tricky, but in normal households, your tips definitely help.
My advice: regularly check the edges, do small paint touch-ups, and always ensure good ventilation. That way, the PLATSA dream lasts a long time – even in the hallway, where we often have wet shoes.
