ᐅ How can I protect IKEA PLATSA furniture during renovations?
Created on: 16 Sep 2024 10:37
Larrychen
Larrychen
16 Sep 2024 10:37
Hello everyone, I am currently planning a renovation of my apartment, which involves my IKEA Platsa furniture. Since these pieces seem quite delicate and I want to avoid any damage during the work, I’m wondering: What is the best way to protect IKEA Platsa furniture when painting, doing floor work, or other renovation tasks? Are there any proven methods or products that work particularly well to protect the surfaces, edges, and joints from scratches, paint splatters, or other damage? I look forward to your tips and experiences!
sanjon
16 Sep 2024 11:03
It is best to cover all furniture completely, preferably with thick plastic sheeting plus painter’s fleece. Otherwise, remove what is possible and store it safely. Paint splatters are easiest to remove immediately with a damp cloth.
RENMA
16 Sep 2024 12:22
When renovating IKEA PLATSA furniture, I recommend a systematic approach: - If possible, disassemble the furniture or at least move it to avoid direct contact with building materials. - Use breathable painter’s fleece for protection: it prevents scratches and can handle the slight moisture that often occurs during renovations. - Protect edges additionally with foam or edge protectors, as these areas are especially vulnerable. - Create paint and dust protection by thoroughly covering surfaces; ideally, immediately remove paint splatters with a slightly damp cloth so they don’t dry. - Do not store tools and materials directly next to the furniture to avoid accidental damage from dropping or bumping.
Ramon4
16 Sep 2024 14:09
I can agree and add the following: If dismantling is not possible, I would specifically protect the edges with duct tape or special cushioning film to absorb impacts. If you plan to paint, definitely use painter’s tape at the contact points to keep paint splatters away from the furniture. Also, when working with moisture, pay close attention to direct dampness on the furniture—especially the back panels, which are often sensitive in PLATSA. During renovations, I have sometimes used very thin bubble wrap as protection—it cushions impacts better than smooth films.
Larrychen
17 Sep 2024 09:14
Thanks for the tips so far! I am still curious about the storage of the individual modules when I completely disassemble the furniture. Are there any specific conditions I should be aware of to prevent damage to the panels and joints (e.g., from moisture, warping, or other factors)? Also, how do you manage when space is limited during renovation? Thanks in advance!
Dilen
17 Sep 2024 11:47
This is a very important point. PLATSA modules are basically made of particle boards with a foil coating, which are relatively sensitive to moisture and heavy mechanical stress. Therefore, please observe the following: - Store the individual parts flat, not on edge, to prevent warping. - Place a clean underlay beneath the boards, such as a rolled-up blanket or a thin plywood sheet, to avoid scratches. - Avoid artificial sources of moisture nearby; basements or damp garages are generally unsuitable. - If stacking temporarily: always place heavier parts at the bottom to prevent the lower boards from being crushed. - Keep connection fittings (screws, brackets) sorted and sealed airtight. - In case of limited space, I would recommend minimal disassembly, at least removing the fronts to reduce the risk of scratches. - If a move is planned: use moving blankets or bubble wrap to protect against damage from impacts during transport. I have done this several times myself and it works well.
